Ultimate goals for a N/A 3V GT... Need some advice
I plan on making the power for my car through a N/A setup for AT LEAST the next three years. With that said and the mods listed in my sig (2008 automatic Mustang GT), what else would I need to possibly creep past 400 RWHP N/A? What would be the best heads? Best Cams? Any other suggestions?
Damn cuz, over 400 ponys you say, and at the wheels nonetheless..
not sure about heads or cams but as far as other suggestions go..
I picked up 15rwhp with my HP head rest, and another 10hp with a custom window decal. Maybe that in combo with a serious ground wire kit setup will put you up over the 400rwhp mark. Alright, i'm done.. my b
Ant, where my headers at???
BTW nice lip and spoiler..
the DS wont really get you any hp. but i like my spydershaft. no vibration, quick thru the rpms. i heard good stuff about comp cams. and that is probly a good idea of building the bottom end first. but i wouldnt be so concerned about the 400 rwhp threshold. i mean its a number. i think having a solid bottom end that works well and is ready for the next step is more valid.
P&P Heads and a Stage II cam will certainly help out. May as well do the Delete Plates as well while you are in there, then get it custom tuned.
Mine is undergoing that transformation over the next couple of weeks. Its sitting in a shop disassembled now - just waiting for parts. I'll be hoping to reach 350+ RWHP with those mods along with the others, which are similar to yours. 400 is certainly a number I'd like to see at the wheels too, but figure a 12-15% loss from the crank and we'd need to make 450ish at the crank to get that.
I'm using BBR's stage II cams - springs required. A local shop is doing the port/polish. And I'm putting on American Racing LTs.
While not a step by step how to get 400 rwhp, the article titled Mercury rising, done by MMFF.
Shows that it can indeed be done, but with the compression ratio they run to get it, you would have to change out pistons to lower it, if you wanted to go FI.
I think with careful planning, you could get close to your goal, with parts that would still be supercharger friendly.
