Charge Motion delete plates?
I have a question about how to have an inspection done if I have charge motion delete plates on my car. Can Brenspeed send me a inspection friendly tune so I can pass with the cmcd's ?
If I am correct; if you do not currently have a tune for the delete plates, you are going to need a new tune after you install them. Are they already installed ? If so, and you have a tune for them, then you should be fine if you do not have a CEL.
This is to the best of my knowledge, but I am not 100% sure
I have the stock H so i can just throw that on when I have the inspection done, I will have Brenspeed send me an inspection friendly tune. Just wasn't sure if the delete plates would effect anything.
I have delete plates and they wont affect your inspection. You do need Brenspeed to write you an inspection tune, though. Its so they can turn the o2 sensors back on. They're off by default on their tunes. They wrote mine free of charge when I bought my setup from them. After 2 years I finally had to use it this past March and it worked like a charm. I forgot to load it my first go 'round and the car failed. I loaded the tune the next day and drove to the shop and passed. Hope that helps.
And if that is the case, what happens when i get a tune without cats when i decide to remove them ? They should then infact turn off the rear o2's if they are not turned off already right ? And how would I pass inspection then ? Put the cats back on and have them send me a tune to go along with putting them back in ?
