Help!
Help!
I bought a 2008 Bullitt in the u.s.a and brought it up to canada. For me to register the car it has to pass an inspection. In canada we need day time running lights. The trick is the head lights are HID lights and nobody up here knows how to hook up the drl lights with hid lights.
Any advice is greatly appreciated for i have a beautiful car that is sitting in my garage
Thanks
Thanks
The issue is you DON'T have fog lamps, if you did the drl option would be turned on and the fogs illuminate. Only way I see to do it is add fog lamps, personally I wouldn't w/Bullet but it could get you to pass inspection then swap out your fogs/grille for the Bullet after the inspection.
Dont worry. StangMods.com has a harness that will convert your parking lights into DRL. Here is the link:
http://www.stangmods.com/Mustang-Day...ts-p/00933.htm
Hopefully this helps.
