Shane's E-Force Install Thread
Old 04-13-2010, 12:55 PM
  #171
rm9792
rm9792's Avatar
Originally Posted by shanec
Ditto - its an easy, just time consuming, install. Unless you get an early run model like I did which comes with a faulty throttle body, mis-tapped bolt holes for the fuel rails, no bolts for the supercharger pulley, wrong set of spark plugs, no instructions for the GT500 fuel system, a PCV hose outlet pointing at the wrong angle, the wrong connector pre-pinned on one of the harnesses, and a tune (from JDM) written for the wrong air intake kit.
Seriously, find out what serial number you are getting. And check the hand-written number on the parts list that comes in the accessories box and make sure that matches the serial number for the supercharger.
I don't know what serial number they're up to now. I don't know which serial numbers had fixes for all the issues I ran into. I'd guess if you aren't serial number ~500 or greater, I'd suggest opening all the boxes to check all the parts, check for threaded bolt holes (test fit the screws - sometimes only the top 2 threads are missing, and call Edelbrock to confirm the throttle body is worth a crap).
I dont know about all of those issues with mine, the Ford delaer installed it. I did have to replace the throttle body motor, and the tune would not work from edelbrock. Threw random codes and failsafed within 10 minutes every time it started. Dealer gave up and sent to a tuner/dyno shop and was running great with thier tune after about 6 hours. What serials were problematic? Also, i had to buy the GT500 fuel setup seperate so are you saying your box came with it?
rm9792 is offline
Old 04-15-2010, 11:05 PM
  #172
shanec
shanec's Avatar
My Edelbrock kit was the tuner kit - which is basically just the supercharger plus whatever the dealer (JDM Engineering) puts together with it.
http://www.teamjdm.com/shop/product_...32&cPath=35_81
This particular kit included the GT500 fuel system.
shanec is offline
Old 04-16-2010, 03:23 PM
  #173
brad281
brad281's Avatar
Shanec, is the e force still running strong on your stock internals? Any problems at all?
brad281 is offline
Old 04-16-2010, 03:26 PM
  #174
candymanjl
candymanjl's Avatar
totally off topic but it's hilarious to me to have a domestic shop named "JDM Engineering"
candymanjl is offline
Old 04-17-2010, 05:50 PM
  #175
shanec
shanec's Avatar
No problems on the stock internals. I'm not real hard on the car though. Its never going to see the track. Its a daily driver and I enjoy blowing by folks on the highway now and then.
...even so, the clutch managed to last only 3 months. It was slipping some, so I replaced it. I put in a Centerforce DFX and Centerforce flywheel.
shanec is offline
Old 04-17-2010, 05:51 PM
  #176
shanec
shanec's Avatar
eh, I don't get it.
JDM is the owner's initials.
shanec is offline
Old 04-17-2010, 05:55 PM
  #177
candymanjl
candymanjl's Avatar
eh, I don't get it.
JDM = Japanese Domestic Market
every import owner strives to make their car more "JDM" with their mods and how it looks, I guess it's just funny to me coming from imports to see a domestic brand say "JDM"
mtgldr
02-03-2024 09:00 PM
TimeLord101
09-04-2015 09:27 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: Shane's E-Force Install Thread
