View Poll Results: A poll
Felt a big difference, well worth the money.
37.50%
Felt some difference, still worth it.
43.75%
Not sure, but think there is some improvement.
6.25%
No difference at all.
6.25%
Seems a bit worse overall.
6.25%
Much worse than stock, big disappointment.
0%
Voters: 16. You may not vote on this poll
Canned Tune...Worth it or not?
Old 07-13-2005, 10:08 AM
nbk13nw
nbk13nw's Avatar
Default RE: Canned Tune...Worth it or not?
Stuff?[sm=alcoholic.gif]
ORIGINAL: DAVE05GT
ORIGINAL: GGIII
I found a significant difference with a Diablo, especially with the stock Throttle-By-Wire. I'd recommend it if you don't have a dyno nearby as the Diablos are quite customiZeable. ((Blah! My Z key wont work if I don't hit Shift. =p))
You should try to stop "spilling stuff" on your keyboard.
nbk13nw is offline
Old 07-15-2005, 01:05 AM
Redfire
Redfire's Avatar
It's nice to see that some of you finally replied to this. Though the responses were few, it seems the general consensus is that the canned tunes ARE worth the dough. But I have to tell you, I'm really wrestling with myself on spending $650 for a C&L and a Predator. That's about $25 a lousy horse! Still, Ide like to have the son of a be-atch though!
Redfire is offline
Old 07-15-2005, 01:30 AM
Herknav
Herknav's Avatar
ORIGINAL: Redfire
Keep in mind that you are paying for the utility of the Pred... it will get you more horses down the line as you make more improvements... got a CEL, plug in the Pred and find out what it is... I did this... CEL after putting the C+L in and putting the correct (I thought) tune in... CEL... hmm... engine is too lean... WTF... then I looked and realized I put the wrong tune in... tada! No more CEL. Heck, you can even turn the speed limiter off... If it helps, consider the Pred seperate... consider it a diagnostic tool and the C+L gives you something like $10 a horse... acceptable???
Herknav is offline
Old 07-15-2005, 12:52 PM
SMP
SMP's Avatar
hawgman how did you do that? 299?
Can i see your dyno and compare?
can you send your tune file?
What is your A/F Ratio?
What Octane did you tune?
was dyno tuned on Wed and here are some results:
http://s36.yousendit.com/d.aspx?id=2...E07UP3AU36F3AU
MOD:
C$L CAI
Bassani Axel Back
Bassani XPIPE WITH COMP CATS
Diablo Predator with my S.T. Motorsports custom dyn0o- tune done by Adam.
Revlimter moved up to 6500
Weather was hot as crap about 105 outside the shop...
MAX POWER 285
MAX TORQUE 300
A/F Ratio 12.6- 13
Notes:Adjusted Revlimter up to 6800. Noticed that it had some power at 6000-6300 or so. Then we readjusted the rev limiter back down to 6500 because we noticed power decrease just before that. Then we adjusted the variable cam timing. I must of had about 10 pulls or more...
I am taking it back on sat because we want to see were it is at in cooler temps. I thouhgt i could pull 290-95 MAX POWER, dyno's hurt feelings but i still think 290-295 is possible.
DYNORUN 1 BASELINE-
MAX POWER 271.00
MAX TORQUE 288.2
[IMG]local://upfiles/10979/FB7C5E6D0AAA42BA9C1C49DA26031636.jpg[/IMG]
SMP is offline
Old 07-15-2005, 05:41 PM
nbk13nw
nbk13nw's Avatar
I am sure that if the temp was 30 degrees cooler that the hp / tq would be up where you would not have been disappointed.
ORIGINAL: SMP
MOD:
C$L CAI
Bassani Axel Back
MAX POWER 285
MAX TORQUE 300
A/F Ratio 12.6- 13
DYNORUN 1 BASELINE-
MAX POWER 271.00
MAX TORQUE 288.2
nbk13nw is offline
mrreynolds80
09-19-2015 07:37 PM
thesambox
08-19-2015 09:39 PM
Hillbilly1968
08-19-2015 12:03 PM
Daleford
08-10-2015 08:30 PM
dangthatsfast
08-06-2015 09:46 PM
Quick Reply: Canned Tune...Worth it or not?
