"clunk" from drive shaft or pumpkin?
Old 09-02-2009, 10:00 PM
Monkeyleg
Monkeyleg's Avatar
Default "clunk" from drive shaft or pumpkin?
Every so often, when shifting gears, I can feel a "clunk" in the drivetrain. I don't really hear it, although there is a noise.
It feels like a worn u-joint would, but doesn't happen all the time. I'm pretty sure it happens when shifting into 2nd. I don't remember it doing it when shifting into other gears.
I've tried backing up and moving forward to see if it was a u-joint, but no luck. The car has been lowered 1.5", but I would think that any noise from the differential related to that would be more constant.
Any ideas?
Monkeyleg is offline
Old 09-02-2009, 10:01 PM
Riptide
Riptide's Avatar
Pretty sure it's normal. I've heard the same thing on mine. Especially going from 1st into 2nd.
Riptide is offline
Old 09-02-2009, 10:27 PM
Lifter583
Lifter583's Avatar
Hey Riptide..hows life over in Montaner?
I went to a Dynotech 3.5 aluminum...cant believe the difference! Everything is tight and positive...the clunking and play comes from that 43 lb 2 piece boat anchor...
Lifter583 is offline
Old 09-02-2009, 10:33 PM
Riptide
Riptide's Avatar
It's awesome are you coming up for the 30th international mustang meet this weekend? It's in billings.
Nice choice on the dynotech. It's the one I'm eyeing. Probably score it next year after I finish paying this thing off.
Riptide is offline
Old 09-03-2009, 12:04 AM
Sleep Deprived
Sleep Deprived's Avatar
I get the same clunk with the Spydershaft that I had with the stock 2-piece driveshaft.
Sleep Deprived is offline
Old 09-03-2009, 08:00 AM
mac10chap
mac10chap's Avatar
me too...
mac10chap is offline
Old 09-03-2009, 03:42 PM
157dB
Cut & Paste Expert
157dB's Avatar
I had the clunk and the front driveshaft yoke flange bolts were loose.
It was apparent that the flange was spinning ever so slightly within
the sloppyness of the attaching bolt holes.
Been good ever since...
The GT has 2 or 4 flanges to check bolts for tightness......
157dB is offline
Old 09-03-2009, 05:08 PM
Monkeyleg
Monkeyleg's Avatar
157db, did you hear the clunk every time you shifted? This is something I only hear now and then. I heard it once today during a 45 minute drive in medium to heavy traffic, but that was it.
It hardly seems like something that would be normal, as it sounds problematic enough that I would think Ford's quality control people would have addressed the problem.
Old 09-03-2009, 05:18 PM
JBALLOY08GT
JBALLOY08GT's Avatar
I hear the samn thing here and there as well....Good to know its not just me..
JBALLOY08GT is offline
Old 09-03-2009, 05:31 PM
moosestang
moosestang's Avatar
I used to get a clunk when getting on or off the gas at slow speeds or maybe low rpms. An adjustable upper control arm fixed that. Now I get lots of clunks when shifting into 2nd gear while turning. I assume this is either normal or my differential is on it's last legs.
moosestang is offline
Quick Reply: "clunk" from drive shaft or pumpkin?
