Looking to purchase a 2005 GT but I have some questions
Old 10-02-2009, 11:58 AM
Mupepe
Mupepe's Avatar
Default Looking to purchase a 2005 GT but I have some questions
I'm looking at a 2005 Mustang GT for my project car right now and to be a stallmate to 2007 Corvette and 2005 Mini Cooper.
But first I had a few questions that I figured you guys could answer best:
1. What does a bone stock 2005 GT typically dyno? I'm sure it's not necessary, but I mean to the wheels, not at the flywheel.
2. Have there been any significant engine upgrades that would make it worth thinking of an older model? I ask because I always kicked myself after getting my 2007 Corvette with an LS2, when for just a bit more I could have gotten the LS3 in the 2008 with 30 more HP.
3. What is typically the weak point of these vehicles? Anything I should worry about? Such as a weak rear end, etc?
4. Anything else you guys can think of that I should probably know?
Thanks, guys! I can't wait to join your ranks.
Mupepe is offline
Old 10-02-2009, 12:17 PM
solidsnakegt89
solidsnakegt89's Avatar
the typical rwhp dyno is in the mid to upper 270 range. HP wise i know for sure that there isnt a difference between the 05-09. now other little diferences if there are any iam not sure about. I like the car a lot iam getting ready to supercharge here in a bit. I never found another car out there that you can have more different kinds of personal mods too...
solidsnakegt89 is offline
Old 10-02-2009, 12:27 PM
sactown
sactown's Avatar
RWHP is anywhere from 265-280 depends on the car and whether or not its a stick or auto.
2010 has 15 more hp I believe. Engine upgrades for 05-09 don't think there is any.
Crank, Rods, and piston. I am on my 5th rearend. and if you push the hp will need a clutch. and a better fuel system and most performance mods for these cars require a new tune.
If you get one go FI!
sactown is offline
Old 10-02-2009, 12:51 PM
Mupepe
Mupepe's Avatar
Great! Thanks, so far guys. The extra price for a 2010 with 15 hp more doesn't seem worth it to me. So I'll stick with 2005
Can anyone breakdown the option packages for me? Or direct me somewhere that has it?
Mupepe is offline
Old 10-02-2009, 12:52 PM
Derf00
Gentleman's Relish
Derf00's Avatar
05/06 mustangs had a number of common TSB and known issues. The main ones being
- Gas fill-up being difficult
- Strut mounts needing replaced with a new revised part number
- Water leak in passenger compartment due to bad seals or seam
- Passenger and Driver side door glass needing "Moleskin" to protect aftermarket tint
- E-brake has been known to "freeze" when we and the temp drops
- Also in cold wet weather the trunk can 'Freeze" shut, a little wd-40 fixs that one.
A completely stock S197 GT Manual will typically net 270ish RWH an Auto around 267ish
This is the current generation so going older would be going backwards unless you get a 4-valve motor like that found in an 03/04 cobra or an 03/04 Mach I
Weak point is the fuel system as in you will almost certainly need to upgrade the Fuel pump if you get FI.
Those are the main ones.
That's about it...Oh, and welcome to the forums
Derf00 is offline
Old 10-02-2009, 01:23 PM
Mupepe
Mupepe's Avatar
Thanks, Derf00. Great info.
And as for my previous question, I'm wondering about the names of models and packages. For example, I see S197 being thrown around while I'm reading threads right now, but I have no idea what it is. Any help in that area would be appreciated. Thanks.
Mupepe is offline
Old 10-02-2009, 03:09 PM
06gt5spd
06gt5spd's Avatar
S197 is the body style name given by Ford. Just like the older models, fox bodys, SN95's and so on. I don't really think there was "packages". There are just the GT or V6, auto and manual and then you just picked from there. The newer models did have some interior packages but I don't think the 05's did. It was all options.
06gt5spd is offline
Old 10-03-2009, 01:00 AM
falcompsx
falcompsx's Avatar
the only other difference is the Bullitt package that was available for a couple years, not sure exactly, but they also had 15 extra hp, due to a different intake and ecu tune.(easily duplicated with aftermarket on a standard model.)
falcompsx is offline
Old 10-03-2009, 10:29 AM
ski
ski's Avatar
The 2005 GT comes as either a Deluxe or a Premium model.
The Deluxe has cloth seats, and a single CD player w/4 speakers.
The Premium has vinyl seats w/leather seating surfaces, and a Shaker 500 audio system(6 CD changer/MP3 player/8 speakers). (The Shaker 500 audio system is optional on the Deluxe model.)
Optional on both models are the Shaker 1000 audio system(6 CD changer/MP3 player/10 speakers/trunk mounted subwoofer), Interior Sport Appearance Package, Interior Upgrade Package(w/My Color), 17" polished alloy wheels, active anti-theft alarm system, front side airbags, engine block heater, and wheel locks.
This link describes the Interior Sport Appearance Package, Interior Upgrade Package, My Color, and the audio systems:
http://bradbarnett.net/mustangs/timeline/05/05/int.htm
Also, 2 other issues are a defective battery, and a defective fuel pump which causes hesitation when accelerating after an extended period of driving at a steady speed.
ski is offline
Old 10-03-2009, 11:14 AM
157dB
Cut & Paste Expert
157dB's Avatar
The Bullitt was offered in an 09 model only.
It offered a different exhaust, a variable octaine tune and a CAI
for 15 more HP.
94-04 - SN95
05-09 and possably the 10' models also - S197
157dB is offline
Quick Reply: Looking to purchase a 2005 GT but I have some questions
