Going racing this Tuesday...
Old 07-14-2005, 02:32 PM
TorchRedBeauty
TorchRedBeauty's Avatar
Default Going racing this Tuesday...
I'm new to street legal racing, but am going to IRP on Tuesday to do some racing and have a few questions. According to the rules, you need a helmet for vehicles running 13.99 and quicker. Will a newbie like me with a completely stock car be able to come close to that (i.e. should I buy a helmet)? Also, do you guys do a burnout before a race to heat up your tires? Any tips would be appreciated too.
-Thanks
TorchRedBeauty is offline
Old 07-14-2005, 02:47 PM
1fast05GT
1fast05GT's Avatar
Default RE: Going racing this Tuesday...
Get a helmet (or borrow one) just in case. Burn out with stock tires IMO is a waste of rubber. Go around the water box even if you are going to do a burn out (don't want to get water in the front tires). Make sure to turn the traction control off. Make sure A/C is off, and all windows up. Take off at around 1,800 to 2,000 RPMs if racing with stock tires (if to much wheel spin try 1,500 next run). shift gears at 6,000 RPMs (speed shift - don't power shift - It'll break traction with stock tires) Hopefully this will help. Good luck.
1fast05GT is offline
Old 07-14-2005, 03:30 PM
RetiredGeneral
RetiredGeneral's Avatar
Get a helmet... nothing sucks worse than running 13.99 on your first run then having to go home...
I've found that doing a burn out on street tires didn't make much difference... most tracks have that sticky compound on the ground anyway.
Don't forget, leave on the last yellow. If you wait for green, you are too late...
RetiredGeneral is offline
Old 07-14-2005, 04:05 PM
TorchRedBeauty
Thanks for the tips, guys. I'll make sure to locate a helmet before going just to be safe.
As for breaking traction, I assume you want to avoid the chirp going from 1st to 2nd or 2nd to 3rd when speed shifting? Or, is it not a big deal since it is such a short chirp.
-Thanks
Old 07-14-2005, 04:15 PM
dc_mann8
dc_mann8's Avatar
no, chirp them hard, shift hard, as long as it isnt losing too much traction, chirping is alright but if it spins for a bit then its too much,
as for the burnout, no dont do one it may actually hurt your traction, and will waste your tires.
just when going up to the line give a quick spin of the tires for a second to clean off dirt, rocks, anything. and good luck!!
dc_mann8 is offline
Old 07-14-2005, 08:43 PM
speedemon
speedemon's Avatar
My 2000 GT ran 13's stock so Your 05 better run a 13
speedemon is offline
Old 07-14-2005, 08:55 PM
dRiBz
dRiBz's Avatar
ORIGINAL: speedemon
wtf, i thought 05s run 13.5 stock, then how does a 2000 run 13.
dRiBz is offline
Old 07-14-2005, 09:44 PM
TorchRedBeauty
I knew that the 05s CAN run in the 13s, but I'm not that confident in my driving yet to assume that I can take the car to it's limits. With some practice maybe...
But, I will find a helmet to borrow just in case.
Old 07-14-2005, 10:02 PM
Spencer069
Spencer069's Avatar
good luck post results
dont forget for help remove spare tire ETC
Spencer069 is offline
Old 07-15-2005, 03:21 AM
Orion_240
Orion_240's Avatar
A couple of questions that might help others:
What is a good model of helmet? I have only experience with motorcycle helmets (Bell). Is there a type specifically for auto racing? Price range? Any links to reputable sites?
Also 1fast05GT, why do you suggest turning the traction control off? I thought having it on would keep it from doing a burnout at greenlight.
With Auto do I shift it or just keep it in D?
Some good tips so far all. Keep 'em coming.
Orion_240 is offline
Florida Regional Chapter
09-30-2015 08:04 PM
guitarman376
09-30-2015 05:54 PM
09-29-2015 03:23 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Going racing this Tuesday...
