Do larger wheels slow you down?
#23
You'll also get less side wall flex when trying to hook up. Less side wall to bend means eaier to spin the tires out and loose your traction.
+1. 20" may have low profile tires...not good for dragracing. More sidewall helps with absorbing the shock at launch, reducing spin and wheel hop.
1st pic shows closeup of our rear tires taking the hit of a transbrake launch (1.4 short time)
2nd pic is complete image, showing both fronts off the ground
#24
For anything other than timed competition (whether that be drag racing or autocross), a couple of lbs per wheel won't matter at all. Even 5 lbs/wheel only ends up being worth a tenth of a second or two on a 40-ish second autocross (by actual test).
Rotational moment of inertai is partly about weight and partly about how that weight is distributed. Mass that's further away from the axle represents relatively more rotational inertia than mass that's close to the center hole. That's really all that can be said about any comparison between/among wheels without knowing more.
If you like to do math (or feel like punishing yourself), a rough approximation that seems to be good enough most of the time divides the wheel weight 2/3 to the barrel (using the MOI equation for a cylindrical ring) and 1/3 to the wheel center section (MOI equation for a circular disc).
As hinted at by 157db, and if you really like to do MOI math, you can also split the tire up into separate tread and sidewall masses for better overall comparison purposes.
Norm
#25
To answer 157db, here are the Webster's dictionnary definitions of the words "wheel" and "rim"
Wheel:
With its cycling/compaction of momentum, reduction of friction and resulting lower amount of work necessary to move items, the wheel is essential in transport. On many wheeled vehicles (for instance, automobiles and motorcycles), a rigid wheel does not come directly in contact with the surface, but instead serves as a mounting point for a flexible tire, usually filled with compressed air.
Rim:
The outer part of a wheel to which the tire is attached.
Wheel:
Rim:
#28
Wheel:
Rim:
Wheel:
Rim:
Ford dont work by Websters definitions. They have their own.
Yep Norm has the suspension answers
right up front wit out thinking bout it.
#29
Okay, here is how I think the issue comes into play.
Assume you have a 17" rim and a 20" rim that both weigh the same, the outside of the rim has to travel 283" per revolution on a 17", where the 20" has to travel 314", the low down is that the 20" has to be moved 10% farther , therefore requireing 10% more energy with the weight being equal... problem is that the weight is rarely equal.
For another example think back to break dancing or ice skating, when the guy is spinning on his back or the ice skater just spinning, they pull their weight in closer to the body which results in the ability for the energy already expended to increase the rotational speed.
I think that's the theory anyway.
#30
Found this information a few days ago when doing a search on a related topic and saved it. I don't know how reliable the info is, but it sounds right.
17" Bullitts are 21.5 lbs
18" Polished Bullitts are 25 lbs
18" Chrome Bullitts are 26.5 lbs
18" Fanblades are 27 lbs
18" GT500 Wheels(07 - 09) are 29 lbs
