Irregular idle on Deceleration
Old 01-29-2010, 11:46 PM
simplexdesign
simplexdesign's Avatar
Default Irregular idle on Deceleration
I recently starting having a problem with my RPM Idle and was wondering if anyone else has shared the same problem and has any info. It usually happens when I am slowing down and I put the car in neutral the rpms will go down and then start jumping around under and over 1k without applying the gas pedal at all. At high speeds slowing down quickly with make the Rpms drop so low the car will shut off. The only real motor mod is a tune and intake by brenspeed running a 91 octane tune with exhaust work.
simplexdesign is offline
Old 01-30-2010, 12:05 PM
ski
ski's Avatar
If you recently reinstalled the tune or disconnected the battery, then drive around for 20 miles or so, and see if that clears things up.
If it still happens, then there's a procedure in the battery maintenance section of the owner's manual that addresses an erratic idle.
If you did not reinstall the tune or disconnect the battery, then make sure all of the air intake connections are secure.
If they're ok, then clean the MAF sensor and TB.
If no luck, then either the TPS or TB may be bad.
ski is offline
Old 01-30-2010, 04:16 PM
simplexdesign
The Battery was discounted when it was back in the bodyshop a few weeks ago but it has been driven well over 20 miles and is still doing it
Old 01-30-2010, 04:55 PM
Simon1
Simon1's Avatar
You should be asking Brenspeed. It's a tuning issue.
Simon1 is offline
Old 01-30-2010, 11:37 PM
Black_Steed
Black_Steed's Avatar
This happens to me also. When i am slowing down for a red light and i put it in nutural the RPMs will jump around with out me applying any gas.
Black_Steed is offline
Old 01-31-2010, 01:19 AM
simplexdesign
Glad its not just mine but now makes me more curious as to what it is. You do have the same brenspeed tune
Old 01-31-2010, 01:16 PM
HypromanGT
HypromanGT's Avatar
I believe some people have fixed this by cleaning their throttle body and/or the MAF sensor. Could be worth a shot...
HypromanGT is offline
Old 01-31-2010, 07:16 PM
Black_Steed
A friend of mine has a 06 gt with about 60,000 miles on it and it is bone stock and he was also telling me his car is doing the same thing when slowing down. My car is a 08 gt and only has 17000 miles on it hope it is nothing bad.
How should i go about cleaning it? I thought you were not really exsposted to touch the MAF sensor,
Old 01-31-2010, 09:54 PM
HypromanGT
HypromanGT's Avatar
Oh, boy. I had a feeling that questions was coming I personally have NOT done this before, so please take my advice at your own risk. I believe there is such a thing as "MAF Cleaner" that you can use (obviously) on the MAF. Likewise, I believe that there is a throttle body cleaner for cleaning the throttle boy. You're best bet is to wait for someone else to chime in here and/or search around the forums; I know it's been mentioned several times before.
Last edited by HypromanGT; 02-01-2010 at 09:25 AM. Reason: Added a bit of clarity.
Old 01-31-2010, 10:24 PM
TXHP08GT
TXHP08GT's Avatar
The same thing happened to me 3 months ago....my buddy told me to check my spark plugs and there was the problem. 4 of the 8 were completely out. I changed them and its been running like normal now.
TXHP08GT is offline
Quick Reply: Irregular idle on Deceleration
