Aluminator build.
#21
Sorry to hear about your blow up but nice job on the rebuild.
Of course, given that you had the motor out and stripped, I should get on a plane and come slap you in the face for refitting those uglyass valve covers without coating or painting them first of course... But hey
Hope you have a great many fun filled miles with the new lump
#22
Well I FINALLY got my GT500 TB today. I am going backwards I swear!!!
Put it on, first thing I noticed is that the fuel line is scrapping off of it. This is due to the taller 60lb injectors. So I bought Fore Precision fuel rails from Lethal! so the fuel intake comes off the front of the rail instead of the top. I can also change the fuel pressure sender location so the intake is not sitting on the sender the way it is now.
Second problem is that the TB does not fit!!!!!! I will probably try switching the TPS over from the stock one to the GT500 one and see if it works! (Stock one is 1/4"-3/8" narrower!) Anyone done this?
I also have another project on the go on the inside of the car. But that is for another thread!!!!!!!
#23
one step forward and 2 steps back with 3 forward....car is a work in progress and never give up explict! Thanks for posting and just curious are those the final numbers in your sig pic?
#27
Got dyno tuned by Eric Brooks at Horsepower Solutions this past Thursday. Made 525whp. Dont have my slip yet.
Went to a car show today and won Best Car!!!!! Then on the way home this happened....
Blower pulley bolts snapped and the pulley came right off. I am not happy about this and I hope Steeda helps me out BIGTIME.
#29
How did that happen? One time I had an idle pulley go and it twisted the belt at the snout of the blower and my blower started leaking so I had to have it rebuilt. You got lucky that it did no other damage to your car.
Thanx-Muzzy 04 S281SC Convertible #355
42#
JLT cold air
JDM SCT 93 oct tune
90mm maf
75mm TB
Ported and Polished SC by PSE
Mosaleen pulley sys
Gaterback belt
NGK tr6 @034
2.9 pulley
Chicane ss braded IC lines
Carbon fiber dash kit and shift ****
1 bottle of water wetter (haha)
42#
JLT cold air
JDM SCT 93 oct tune
90mm maf
75mm TB
Mosaleen pulley sys
Gaterback belt
NGK tr6 @034
2.9 pulley
#30
