Auto trans. flush.
I have heard from many people saying not to do that. Flushing can move a lot of junk around that you would prefer not to disturb. The best way is to drop the pan, change filter, refill with new fluid and leave it alone. The new fluid and filter will catch the sediments and junk in time.
Not really sure how flushing could possibly hurt anything. It's basically a transfusion.
All the work is done by the cars pump, not the machine. Line in takes the old, line out puts in the new. There is no damage that could possibly happen, sorry guys.
And the trans filter is basically a metal mesh screen. Nothing like an oil filter.
You would get more debris out by dropping the pan, and cleaning the magnet if there is one in these trans pans.
Personally, the best way is to drop the pan, change filter, clean magnet, drain the converter.
Flush machines are far from 100% fluid exchange, but they do not do damage.
Well, you got some wrong information on the fluid exchange process. Or a machine type that I have never heard of, nor can find on the internet. Some mention "pressurized" and that is still all from the converters power, not the machine. The old stuff is pumped into the machines cylinder, pressurizing that end of the cylinder and forcing the new stuff out into the car. The only pump in the machines is to fill it with new fluid and dispense of old fluid.
The filter, that is totally possible, I personally haven't seen any trans filters myself in a long while, but am very familiar with most common transmission "flush" machines, which should and most of the time are called, fluid exchange machines, not to confuse anyone with an actual flushing of the system.
T-Tech process is powered by the vehicles own pump, eliminating the dangers of over- or under-pressuring the system
Auto-alignment feature means there is no need to verify fluid flow prior to starting and no possibility of a reverse connection.
