19 inch rims? tire question help
hey guys quick question. I bought 19 inch rims 19x 8 in the front and 19x10 in the back. What are the right size tires for these rims. 4 weeks ago i had asked the same question and one guy on here gave me the wrong tire size after i asked 3 times if he was sure so your guys input would be great.
I'm running 255/40 on 8.5 fronts and 275/40 on 9.5 rears. Not quite the same as your wheels, since your rears are 2 inches wider than your fronts.
I tried 285/35's on the rear and they fit the wheel nice but are actually the same height to slightly shorter than the 255/40 fronts, which I didn't like. If my rears were wider (10.5") I would be looking for a 305/35
You have several options, depending if you want the same height front rear, same height as stock, etc...
What were you told in the past?
Calculated tire width and height for the combinations posted. Will vary a little across manufacturers.
255/40/19 - 10.0 x 27.03
275/40/19 - 10.8 x 27.66
285/35/19 - 11.2 x 26.85
245/45/19 - 9.6 x 27.68
Stock 235/55/17 - 9.25 x 27.17
Any of the combinations listed will work fine.
If you go to Sparta's set-up they will look like what you have already, only wider and slighly shorter.
If you want the fronts to not "appear" taller than the rears and have a nice rake to the car, put a set of 255/40's on the front and keep your rears.
There really is no perfect answer. It is up to your taste at this point. I posted the sizes so you could get a feel for what the different sizes actually look like. It is easier for me to visualize when I can see numbers.
