I NEED GEAR RATIO SUGGESTIONS
Old 08-07-2005, 01:59 PM
Weedo
Weedo's Avatar
Default RE: I NEED GEAR RATIO SUGGESTIONS
ORIGINAL: Turbo 05
with the extra power you have from the blower you shouldn't need gears all that much, your 1/8 mile times are slighly better then stock if not equil, i would invest in learning how to drive your car and getting it tuned and I am sure you could drop alot of those times. I wouldn't go any more then 3.73 if you do the gears, with the increase in HP you dont want to use up your top speed to much with gears.
I have to disagree. Again, the higher you can stay in the RPM band the better. 3.73's will drop you lower in the RPM band on each shift than the 4.10's, and won't get you to peak power as quickly. Overall I don't think it will make that much difference, but for the same money, go with the gear that will yeild you quicker times (4.10's).
Weedo is offline
mtgldr
02-03-2024 09:00 PM
Jb145700
08-21-2022 06:37 AM
articman
06-21-2018 11:45 PM
ccdguy
09-19-2015 05:20 PM
09-03-2015 07:14 PM
Quick Reply: I NEED GEAR RATIO SUGGESTIONS
