need to know more about fluids plain and simple?
Hey guys I just noticed that my power steering and my engine coolant is running a little low what should I use for the power steering and for the engine coolant. Can I just add it or does it require everything to be flushed. Thanks guys I just want to know this stuff so I don't got to ask again and know something so simple
Well my coolant and power steering fluids bout a little less than half inch my stang gt is a 2008 with 20000 miles I just found it bizarre that Its below the low level and with that mileage. What do you guys use for those
Engine coolant expands with heat. You probably checked it cold instead of hot like you normally do, or something of that sort. I wouldn´t worry about anything unless it turns chronic, especially at your mileage.
Steering fluid, I forget, I don´t think it changes much in regards to temperature.
My previous stang was 12 years old, 150,000 miles, and no fluid flushes. It was fine
jwog666
12-27-2021 08:09 PM
09-25-2015 06:42 PM
