2011 GT Satellite Antenna Fault?
I added in the Pac-Audio adapter (link below) to my car so I could add in my amp and sub. Everything sounds great. The only problem is I now have a satellite antenna fault and cant use Sirius Radio.
Has anybody else had this issue or know how to fix it?
Here's the adapter:
http://www.pac-audio.com/productDeta...&CategoryID=28
Here's the adapter:
Try disconnecting the negative lead on the battery for 20 minutes
and see if the situation clears up.
I dont see the corrilation between a PAC CANBUS adapter and a
satalite receiving antenna.
Maybe you overloaded the trunk and killed the sat radio antenna lead.
I just had a 2011 gt in the dealership yesterday with the same problem(without the addon) The Antenna just cut out... no idea why, it just stopped working. To fix it you need a new antenna... or you might have accidentaly disconnected the sat radio/nav antenna cable
Where does it plug in?
With running allthe power wires, hiding them under the carper, installing the adapter, tuning everything (so you don't get a signal over load on the input side of the amp), and then putting the back seats in and the rest of the car together it took me about an hour start to finish. That also counts putting in a switch inline on the remote wire and mounting it to the panel next to my right knee so I can interrupt the signal from the remote wire to power on/off the amp (my wife hates the funk in the trunk).
BeatnikFink
10-01-2015 08:00 PM
