Exhaust dilema
Old 12-06-2010, 03:20 PM
iceguyb14
iceguyb14's Avatar
buy my pypes violator mufflers. they are quieter than the pype bombs, but still give a lot of volume.
iceguyb14 is offline
Old 12-06-2010, 04:53 PM
onederful100
onederful100's Avatar
option 1. switch to o/r x pipe
option 2. change out the catback including the glasspacks for a different axle back without the glasspacks.
the cats + the glasspacks are making it too quiet. you gotta take out 1 of the 2.
it will be easier to switch out the midpipe. unless you have to pass inspection.
onederful100 is offline
Old 12-06-2010, 05:47 PM
gman73
gman73's Avatar
Perhaps the glasspacks are too long. I had a prochamber w/hi-flow cats with SLP LM. That set-up was a little too loud for me, so I had 14" (from tip to tip) glasspacks/resonators welded in. This took away enough of the volume and it was still loud enough. I then swapped the prochamber for a pypes catted x. This changed the tone slightly. Next I picked up a set of MACs and would swap them with the SLP LM every so often. Believe it or not, the MACs sounded better with this set-up.
gman73 is offline
Old 12-06-2010, 06:48 PM
Thor
Thor's Avatar
I think I will try a different axle-back. I no longer have the stock H-pipe and I don't want to remove the cats and then have to put them back when inspection time comes.
Thor is offline
Old 12-06-2010, 08:32 PM
gman73
gman73's Avatar
I don't think you can get much louder than pype bombs. Perhaps SLP LM or Pypes muffler deletes would be a little louder.
gman73 is offline
Old 12-06-2010, 09:19 PM
Thor
Thor's Avatar
I actually heard SLP LM are quiter, that's what I was considering getting instead. The Pypes without resonators were very loud and had a great amount of drone.
Thor is offline
Old 12-06-2010, 09:36 PM
onederful100
LM or deletes will be slightly louder than the pype bomb
the pype bomb is somewhere in between LM and boomtubes
boomtubes have more baffles inside vs the pype bomb, and LM have none.
some of that drone is coming from the cats.
i think your easiest solution is to go to a catless midpipe.
Old 12-06-2010, 09:54 PM
Thor
Thor's Avatar
I might also want to get Long Tube Headers somewhere down the line so the Pype Bombs and SLP's aren't sounding so good anymore lol.
Thor is offline
Old 12-06-2010, 09:56 PM
Thor
Thor's Avatar
Do you think the SLP's would have as much drone?
Thor is offline
Old 12-06-2010, 10:04 PM
onederful100
i think the sound with the LM's will be similar to the pype bombs
Quick Reply: Exhaust dilema
