OK, I'm a moron. Now what? Ran with no oil
Old 01-16-2011, 10:39 AM
  #61
MrChicken
MrChicken's Avatar
I'd guess that your dipstick would pop from crank case pressure long before the oil filter seal.
I havent worked on that motor but I'd think you'd need serious oil pressure to pop the seal having seen ordinary filters stay sealed at 100psi on other morors.
MrChicken is offline
Old 09-01-2014, 11:05 AM
  #62
157dB
Cut & Paste Expert
157dB's Avatar
I havent worked on that motor but I'd think you'd need serious oil pressure to pop the seal having seen ordinary filters stay sealed at 100psi on other motors.
Crankcase pressures do not effect the oil filter seal.
Not sure where you are going on this one...
157dB is offline
Old 09-01-2014, 12:01 PM
  #63
yourmom6990
yourmom6990's Avatar
This post is over 3.5years old.....
yourmom6990 is offline
Old 09-01-2014, 12:22 PM
  #64
Rudolph Hucker
Rudolph Hucker's Avatar
i just read this entire thread..
terrible and hard to read....hope the op got it all sorted
Rudolph Hucker is offline
Old 09-01-2014, 07:37 PM
  #65
cruisin5268d
cruisin5268d's Avatar
It's probably a bit late to be joining in on this thread..
cruisin5268d is offline
Old 09-07-2014, 11:31 AM
  #66
Bostonbuster
Bostonbuster's Avatar
You ran it for less than 15 minutes or so ? Just drain the oil and step up to 10-w30 and drive it. You may of had a sufficient oil film to minimize damage. I ran an old school Boss 302 with a seized oil pump for 3 or so miles once and a 260 fairlane for 14 miles without oil pressure , most likely you have some main bearing damage , a thicker film oil could help. nothing to lose motor could run ok for another 20 k or so.
Bostonbuster is offline
Old 09-08-2014, 01:25 PM
  #67
kingstrider
kingstrider's Avatar
Wow that sucks. My neighbor did that once with a numbers matching 1970Chevelle convertible 396. Within moments it wrecked the original engine and he wound up having to replace it with a crate motor instead.
kingstrider is offline
TCStangerv6
10-11-2015 05:57 PM
Florida Regional Chapter
09-30-2015 08:04 PM
wraith777
09-28-2015 10:49 AM
Shadow7874
09-24-2015 09:06 PM
ctgreddy
09-20-2015 08:35 PM
Quick Reply: OK, I'm a moron. Now what? Ran with no oil
