LT install. Need some quick help with engine lifting point.
LT install. Need some quick help disconnecting steering rod.
Now I need help with the steering rod. Is the little brown bolt the one that needs to come out?
Alright, I'm 2 hours into my install, been going smooth so far.
What I've read says to use a 2x4 under the passenger side of the block to raise the engine. Where is that spot?
Here's my under shot. Am I even looking in the right area?
There are two ways I know of to jack the motor. One is to put a telephone book under the pan, then a board and jack on the board.
The other involves using a piece of billet metal along the front oil pan bolts and using that for a jacking point.
Good luck.
Good luck.
musnicki
09-23-2015 07:11 AM
Insidian
Carolina Regional Chapter
09-08-2015 05:33 AM
