Ramps
Old 12-28-2010, 07:19 AM
t2grr
t2grr's Avatar
Default Ramps
Hi All
Anyone had experience of these?
http://www.autozone.com/autozone/acc...er=391544_0_0_
In the past i have known them to slip away as you try and drive on them, wondered if things have improved.
Thanks
Graeme
t2grr is offline
Old 12-28-2010, 08:04 AM
highline
highline's Avatar
subscribed
highline is offline
Old 12-28-2010, 08:48 AM
dSINtia
dSINtia's Avatar
I've used them with other vehicles I've owned but with the 5.0 lowered I don't have the clearance on the front fascia to get up. as a matter of fact, I would think stock height might present problems. Good luck.
dSINtia is offline
Old 12-28-2010, 08:56 AM
AzPete
AzPete's Avatar
Originally Posted by t2grr
Hi All
Thanks
Graeme
Yep.....they slip faster now......plus I have seen them fold under weight.......I used them on a regular basis until a set folded up with a car on them. Never again.
AzPete is offline
Old 12-28-2010, 10:16 AM
Nuke
Nuke's Avatar
I have Rhino Ramps that I bought from an Autozone for about $50 a few years back (silver/gray color) and even on finished garage floors I've never had them slip. With their rubber feet, the moment the weight of the vehicle touches the ramp mine seem to sit tight in place. Just don't hit them at any speed; roll up gently. I use them on both Stangs and on my SUV.
Looks like the price dropped or I was screwed out of $10. So be it...
Nuke is offline
Old 12-28-2010, 10:31 AM
SCCAGT
SCCAGT's Avatar
OR, do what they did in the olden days. Nail a bunch of 2X8's of various lengths together. Wont collapse. And useful for lowered cars.
SCCAGT is offline
Old 12-28-2010, 10:37 AM
Doogie65
Doogie65's Avatar
Here's a good how-to on making your own wood ramps .
But if money is not important, you could always go with Race Ramps
Doogie65 is offline
Old 12-28-2010, 10:52 AM
onederful100
onederful100's Avatar
i have a set of the rhino ramps from oreily.
they did slide on occasion, but that was on the street with some debris on the road.
so if you do things correctly, they should not slide.
my 2000 GT is lowered 2" and does not clear the ramps
and does not clear race ramps, the 10° regular ones, but would probly clear the extended ones.
my dad built me a make shift extension with various lengths of wood that make the incline less steep
just add a couple of 1" tall pieces of wood to the end of the ramp so it goes up gradually.
and this works on my 2000.
after i drive up the ramps i use jack stands for insurance.
i dont really trust either the ramps or jack stands by themselves.
friend of mine had a jack stand bottom out one time, good thing he wasn't under the car at the time.
onederful100 is offline
Mudflap
Mudflap's Avatar
I have that exact set of ramps you linked down in the garage. They work fine, I've not had any issues with them. The key is to line them up, then kick the ramp under the tire a few times, make sure they are straight again, then just drive right up. The only time I've ever had any ramp slip is when I simply placed it in front of the tires, and drove at them. Wedge them under a little bit and they don't move.
Mudflap is offline
Old 12-28-2010, 02:30 PM
highline
highline's Avatar
highline is offline
Quick Reply: Ramps
