so my clutch is dying, looking for recommendations
#21
Replace the slave cylinder at the same time? Is that a common problem? I always either resurface or replace the flywheel when I replace the clutch, gotta do that.
#22
I get the rattle when I lug the motor and give it a little peddle around the 1700 rpm range.
I daily drvive this thing though. I always run DRs on the street and go the track atleast 1 time a month from March thru Sept. Sactown DDs his also, probably a few less passes though.
I had a new staging official put me back into the water box (even though my tires didn't get in the water), I ended up doing the burnout and smoke poored out of the engine bay from smoking the clutch. Long story short, clutch was just fine and the new official got his *** chewed by me and a few other racers for not putting me in the water.
Moral of the story, this clutch lasts!
Good to hear that it's a resilient clutch, I think I'm leaning towards it. I'll be running 305 DR's all day every day shortly. I know that's going to kill what's left of my stock clutch when I make the switch.
#23
Yes it is ALWAYS a good idea to replace the slave cylinder as well.
Lots of times dealerships or shops will say it is not needed but do not listen to them.
The aftermarket clutches make this needed regardless of what any shop or dealer tells you. If they say something like that just tell them you WANT it done.
This will cause you the pain of having to drop the tranny again in the near future to replace it.
If you don't do it when you install the clutch you WILL come back here later saying you wish you had.
Most aftermarket clutches will finish up the job of the old slave's life for you REALLY fast. They have more of a bite to them.
Don't buy an aftermarket slave though. They are crap.
Just replace the stock one.
#24
Well I do everything myself, never been to a dealership for service in my life ha ha. My car only has 16,000 miles but I'll just grab a new OEM slave cylinder when I replace the clutch, peace of mind if anything.
#25
^ like Black smoke said...
FYI ...IF you go with the Exedy Mach 400 or 500 , it will come with a Slave cylinder. I got mine from BBR and I am pretty happy. Im not sure if the Mcleod comes with a Slave, someone will hopefully chime in.
#28
#29
#30
I drive aggressive but not fast, slightly faster than the limit. I go to work and most days never go into boost. I'm not easy on my car, but I'm no 16 year old driving like an idiot either. That maybe one of the reasons it's lasted this long.
