Supercharged 2008 GT - Oil Consumption
Hey guys, the past times I've changed the oil in my car I've noticed that I only get about 5 1/4 quarts out of the car. So over the course of 5k miles I'm burning about 3/4 a quart.
The car doesn't smoke at all that I've seen and it only has 35k miles on it. I've put about 13k miles on the car since the supercharge install about 11 months ago. So it seems as though it's dating back to about the time of the install. Will a supercharged motor burn/consume oil at a higher rate than a stock motor?
It seems to me that valve seals should be fine with a car less than 3 years old and less than 36k miles. Plus, like I mentioned earlier I haven't noticed any blue smoke.
I'm always use Mobil 1 5w-20 and the car is driving about 250 miles a week, mostly highway. But I do romp on it quite regularly.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
In 5k miles that consumption is considered normal by Ford's standards. Their spec actually allows up to 1qt of consumption in 3k miles. If the car is running well and you get no smoke through the exhaust, I'd say you have nothing to worry about.
Dyson, that seems like a fairly large amount of burnoff but if Ford says its within tolerances, then who am I to argue? :-) The only disconcerting part is that I don't recall having the issue before the blower install.
Bruce, no I don't have a catch can but it's next on my list and yes that volume is including what's in the filter.
BTW, I'm looking at getting the JLT oil separator.
I'm amazed at how much my catch can gathers. The amount of oil you're losing does not strike me as odd on a supercharged motor
Last edited by siggyfreud; 01-02-2011 at 02:06 PM. Reason: Fixed my double negative "doesn't not"
