Two codes thrown..and I need a guru...FAST.
Old 02-22-2011, 01:44 AM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
Originally Posted by SpartaPerformance
I agree that particular codes comes up rather easily with charging system issues. With all the add ons on electronics perhaps an upgraded alternator will do perhaps the one from a Shaker 1,000 vehicle. However these are clutch type alternator so they're not always charging while engine is running so you still may have issues.
Would that be cured with a more powerful battery then?
Get a bigger alternator AND battery?
I will need upgraded wiring not to cause and engine fire though right?
Blacksmoke is offline
Old 02-22-2011, 09:27 AM
Simon1
Simon1's Avatar
Your wiring will remain the same.
The alternator can be taken off and tested. You can try a more expensive battery but most likely the OEM works fine. The battery can be tested too.
Clean the terminals and drive it. See what happens.
Simon1 is offline
Old 02-23-2011, 08:19 PM
Southern Stang 722
Southern Stang 722's Avatar
I had the same code for a while. I was driving normal one day and stuttered like I was tapping the gas multiple times. Pulled the code, and first thought was just clear it and see if it comes back. Haven't heard from it again. But have seen the Misfire code more than once, I need to give bama a call and send another set of tunes.
I installed a pioneer recently also but can't recall the model number off the top of my head. No problems thus far.
Southern Stang 722 is offline
Old 02-23-2011, 10:01 PM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
Got everything tested. It WAS the alternator.
Turns out they have changed the ones they are using in these cars FOUR times since I bought my car and the parts guy was astonished mine lasted so long.
Got it replaced with the latest one.
All is well.
Now to reschedule that tune adjustment!
Old 02-23-2011, 11:06 PM
tx_zstang
tx_zstang's Avatar
Yup, was also going to say alternator. Mine started throwing P0340 codes when the voltage would drop low enough while the car was still running. Alternator fixed it.
tx_zstang is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Two codes thrown..and I need a guru...FAST.
