Del-Sphere LCA's/Clunking sound when shifting...
How closely did the Del-Sphere ends fit up into the axle and chassis side brackets? Did your bolt torquing involve much squeezing together of the bracket "sides"? Enough to clearly see?
And how much clearance is there between the bolts and the holes in all the parts they go through?
Those questions are sort of related if the reason for the clunk is what I think it could be..
Norm
Norm
FYI that is normal. I noticed the same thing when I installed their UCA bracket and arm last month and confirmed with UMI tech support - it's by design.
Also, if you are using UMI roto-joints do NOT overtorque it. I torqued my UMI lowers to 129 ft. lbs. which is the Ford spec and it ruined the joint. Squeezed/compressed it together. Here's a pic of the damage. Don't go past 100 when you torque their stuff or it will destroy it.
I over-torqued my UCA as well (to 129) and from what I can see visually it seems OK. I'm not taking it out to re-torque it. Maybe I got lucky with that one.
Wow I can see how that can happen. Thankfully I did follow the UMI instructions and used their specs. Thanks for the info about the bracket, that always bugged me. I think my next step is to replace all the bolts. Clunking be dammed!
I installed the Spohn Del-Sphere lower control arms on my otherwise stock 2013 Shelby GT500. (only upgrade was a BMR Watts Link). These control arms cause a very noticeable "CLUNK" every time the car is shifted. Rechecked the install and found no issues. Switched back to the stock lower control arms and the "Clunk" is no longer there.
The car has around 16K miles. The Spohn lower control arms joints are the same width stock bushings. I measured them with a good quality digital caliper. These look to be well made and they fit perfectly. They are a little bit noisier during normal driving and over road bumps.
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
