P2020 Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance Bank 2
Old 04-05-2011, 11:09 AM
x under z
x under z's Avatar
Angry P2020 Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance Bank 2
hi,
i have a several problems in my stang 06 make check engine light
and
P2015 Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance Bank 1
+ there is a noisy sound when i accelerate (full throttle) in 1000 to 2800 rpm
coming from the driver side
my stang modifide
cai k&n,summit pully,camshaft comp stage 2,porting heads,long headers 3"
tru-x magnaflow 3" corsa touring catback....
anyway
what shell i do to solve this?
need help
thanx
x under z is offline
Old 09-10-2014, 01:41 PM
bobosh
bobosh's Avatar
what is a Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance Bank
bobosh is offline
Old 09-11-2014, 07:55 AM
bl817
bl817's Avatar
sounds like the idle charge motion plate motor might have gone out on you. with your mods, im surprised you don't have the cmdp (charge motion delete plates). you will need to turn them off with a tuner. there is a good write up on the net to make them yourself and save some cash, that's what I did, or you can buy them for about 300$. im sure you know about them. if not, there are butterfly flaps in the runners that open up at 3000 rpms for stock motors. they are very restrictive. good luck
bl817 is offline
Jb145700
08-21-2022 06:37 AM
JDWalton
09-24-2015 08:47 PM
Big Al's 03
09-16-2015 07:31 PM
TfcCDR
09-14-2015 12:08 PM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
Quick Reply: P2020 Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance Bank 2
