GT500 Front Sway bar has 2 holes on each side?
Old 08-21-2011, 10:38 PM
hollywub
hollywub's Avatar
Default GT500 Front Sway bar has 2 holes on each side?
I am putting in a GT500 front sway bar tonight and I just realized it has 2 holes on each side of the sway bar. The hole towars the back of the car is in the same location as the GT sway bar.
The other hold is a few inches forward.
Can you use this hole to adjust the bar?
Seemed weird to have 2 holes if the forward one cant be used..
hollywub is offline
Old 08-21-2011, 10:42 PM
908ssp
908ssp's Avatar
I seem to remember that the front hole was smaller, no? Too small to use and just makes telling them apart at a glance easier on the assembly line.
908ssp is offline
Old 08-21-2011, 11:00 PM
hollywub
hollywub's Avatar
Didnt look that close. I will check it out.
hollywub is offline
Old 08-22-2011, 11:24 AM
Norm Peterson
Norm Peterson's Avatar
If it's much more than a couple of inches further forward, it would adjust the front bar way too stiff unless you do a bunch of things to stiffen the rear suspension up at the same time.
By itself - fine if you really do want heavy understeer, I guess . . .
Norm
Norm Peterson is offline
RWHEELS
09-05-2015 03:42 PM
TimeLord101
09-04-2015 09:27 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: GT500 Front Sway bar has 2 holes on each side?
