Wiring for the Shaker 1000 in a GT with a Shaker 500?
Old 11-02-2011, 11:06 AM
sgtpat
sgtpat's Avatar
Default Wiring for the Shaker 1000 in a GT with a Shaker 500?
I have been looking around for info about the stereo wiring in my 05 GT Vert. I have read in a few places that all 05's with shakers have the wiring for the 1000 even if its only a Shaker 500. Can anyone back this up with first hand experience or shoot it down the same way? Thanks
sgtpat is offline
Old 11-02-2011, 04:27 PM
157dB
Cut & Paste Expert
157dB's Avatar
Nope, they dont.
Look this over and see what would be
needed for the rear amps and subs...
157dB is offline
Old 11-05-2011, 03:34 PM
sgtpat
sgtpat's Avatar
Originally Posted by 157dB
Nope, they dont.
Opened your link but having problems opening the links it contains. Do you know a better way to get the same info?
sgtpat is offline
Old 11-08-2011, 03:00 AM
wayne613
wayne613's Avatar
audio/video section.
The wiring is NOT there for the rear subs, run from the front to the trunk for the 1000 (which is the only difference between the two).
You'd need to run the missing wiring, or have someone else do so if you are indeed set upon doing this. No idea why most that ask seem to be though.
wayne613 is offline
Old 11-08-2011, 03:29 PM
157dB
Cut & Paste Expert
157dB's Avatar
Yep, if you get the 1000 subs and amps, get the wiring as well...
From the BEC under the hood to the subs in the trunk for the power
and the head unit to the subs for the turn on signal and the low level
bass output. Then you need to get the head unit configured by Ford
with the proper as-built-data so it will put on the lows output....
Total waste of time...
All you end up with is a carpy sheitter 1000 instead of a carpy sheitter 500...
Shot down...
Ker-pow...
157dB is offline
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: Wiring for the Shaker 1000 in a GT with a Shaker 500?
