hydraulic throw out bearing - MustangForums.com
Sponsored by:
Sponsored by:
Old 12-21-2011, 08:02 PM   #1
UsmcMustang
Angry hydraulic throw out bearing
so yeah my car is still down , today i dropped my transmission and well , my throw out bearing ate **** , i have a ram aftermarket slave cylinder , do you guys know if i can just buy a new throwout bearing , or do i have to buy the whole assembly , if i have to buy a new slave cylinder , what do you guys recommend
UsmcMustang is offline   Reply With Quote
Old 12-22-2011, 10:44 AM   #2
hammeron
hammeron's Avatar
pretty sure you need to buy the whole assembly, never heard of anyone trying
to just replace the bearing by itself.
i purchased a new slave cylinder from rockauto a couple of years ago and it's
been working great, good luck with the project.
hammeron is offline   Reply With Quote
Old 12-22-2011, 01:10 PM   #3
sactown
sactown's Avatar
Quote:
Get a new stock TOB. Just curious, why are you running the Ram setup?
sactown is offline   Reply With Quote
Old 12-23-2011, 05:30 PM   #4
UsmcMustang
well i contacted ram and they said i can just replace the bearing , well my clutch went out a while ago so i replaced everything i could with a stronger set up so it wouldnt break or at least last me longer haha , usually if a stock part breaks in my car i replace it with a better aftermarket version
Old 12-24-2011, 02:44 PM   #5
Diabolical!
Diabolical!'s Avatar
The OEM slave/throwout is the most reliable setup.
Diabolical! is offline   Reply With Quote
Old 12-24-2011, 06:39 PM   #6
sactown
sactown's Avatar
stock setup is best in this situation, I had a McLeod TOB and had issue's but the issue's ended up being clutch related.
Old 12-25-2011, 11:12 AM   #7
UsmcMustang
well if this problem continiues i will get the oem setup , i was gonna get the Mcleod one but , this is not the first time i heard that the oem setup is the best
Old 12-25-2011, 05:30 PM   #8
stangs13
stangs13's Avatar
A good thing to remember, aftermarket isn't always the better product!
stangs13 is offline   Reply With Quote
Old 12-26-2011, 11:40 AM   #9
UsmcMustang
you would think it is , since well they saw the oem and thought it could use improvements , but your right as well
Old 12-26-2011, 02:32 PM   #10
stangs13
stangs13's Avatar
It's often assumed that aftermarket is better, and it usually is. But its usually the important stuff that isn't. Aftermarket sensors often don't work as well as the oem sensors do, and have the tendancy to fail. As long as you do a little bit of research you can find the right product!!
What other parts should I be concerned about if my pinion bearing went bad? KingRando 2005-2014 Mustangs 5 10-02-2015 08:06 AM
cost to rebuild heads Drastang 4.6L (1996-2004 Modular) Mustang 2 09-30-2015 03:48 AM
Please help! 10 Check engine codes mrtrodonet V6 (1994-2004) Mustangs 1 09-29-2015 11:13 AM
Loss of power after changing throw out bearing Offendant V6 (1994-2004) Mustangs 6 09-23-2015 07:21 PM
Convertible Hydraulic Cylinder Mikett V6 (1994-2004) Mustangs 2 09-12-2015 10:52 PM
92, bearing, bearings, clip, cylinder, fourth, gear, gt, hydraulic, line, mustang, reliable, slave, speed, swap, throwout
