Vortech Supercharger V3 Brenspeed VS stage 1 KB
I've been going back and forth with SC choices as well. Has anyone looked into the new Magnuson SC for the 2011/2012 5.0? I know most guys go with KB, Roush or other centri SC's, but I was just curious what ya'll thought.
That's what I meant "New to Mustang". They are big with Vettes as well. Just wondering if anyone has ran into or knows anyone who has tried one out with a Mustang yet. Thanks though.
The brenspeed packages are great. I got the paxton novi kit from them. Everything i needed was in the package and the tune came promptly from them. I did the instal myself with no issues. Also got some money off for already having the sct tuner.
Thanks guys. I think I may go with a Magna Charger. I'm sure I can make more power with a centri SC or KB, but putting on a maggie will be different and I like that too.
Wow lots of posts.
My trans is auto.
I dont plan on having brenspeed do the engine upgrades for me.
Good point about the boosta pump vs cobra fuel pump ill have to read up on that. I havnt looked at procharger much, ill look into them today. I believe twin turbo is legal in ohio, my state, but im not sure. I prefer superchargers over turbos but maybe thats a dated view, I guess as long as the power is there who cares how it gets there.
Thats disappointing to hear the brenspeed has trouble hitting higher numbers. I like the KB and whipple but I was really leaning toward a system I could purchase now and upgrade later, and im a bit worried that the kb pushes the limits on the stock motor a bit to far. Ive read the "safe" mark is generally agreed to be around 425 torque, and the KB is closer to 500. Are there any other systems that anyone knows of that starts you out around 425-450 torque and can be upgraded later with good results?
My trans is auto.
Wow lots of posts.
My trans is auto.
My trans is auto.
Think about your purchase before you pony up. Dont do something different because its different. Sometimes it's different because it's not as good. Like the magna charger. Just say no.
You've got a good point. I originally thought about KB until I heard Magnuson was making one for Mustangs and starting thinking about it. Thanks for your input.
With an auto you could go either go twin screw(TS) (KB or whipple) or the Vortech. However, in order to reach the 600 hp range you will need a tranny and engine upgrade. With the TS you can keep the stock stall speed, with the Vortech or Centri blower, you will need to stall the tranny to get the engine into the operating range where it make power if you want to be fast at the track. A pretty dyno number is cool, but when you go to the track and someone making 100 rwhp less in the same car beats you, it embarassing. In my expereince, Twin Screw, turbo and Centri, the TS is the easiest to tune, easist to drive and easiest to make big power. The KB 2.6 will fill your needs, as will the Whipple, at a slightly higher PSI. The KB is bigger and will get you into the mid 600 rwhp range with heads and cams. But it runs a little hotter. The vortech will need to be upgraded to a larger unit to make more power. Consider everything. The KB I have now makes 540 rwhp on a street tune and is faster than anything that should be driven on the street. It ran a best of 11.05 on crap tires, gets 22 mpg on the freeway and sounds awesome.
Humm, good point. Well I guess I am back to TS then. I was leaning towards it before I posted but found the Vortech and the idea of a lower starting cost with investment later was appealing.
My main concern with the KB and wipple is that on a stock engine they are really pushing the limits of what it can handle. Im assuming your not running 540 rwhp stock? Ive read once you go over about 425-450 rw torque, which would be around 450-475 hp roughly, you are gonna start loosing engine components, connecting rods pistons crank and the like.
I plan to eventually upgrade the engine and trans to handle 600+ hp, but presently I would like to keep everything stock, add the sc for some power now and do the engine and trans upgrades later, then increase the boos on the sc.
