CAI and exhaust worth the $?
Wrong, most spent zero to tax, tag and title. Maybe 1% put a decent amount down or paid cash up front. Probably have just enough cash left at the end of the month to make the payment.
My bad. Been awhile since I've been really strapped for cash. Guess I forgot where I was...
Well, money wont REALLY be an issue, as long as the girl doesnt find out..
I'll be using deployment money on it, so will put about $10,000 down to get the payments to $300-$350 a month.. and wanting to go with a CAI w. tune, headers, catted x pipe, full exhaust and LT headers...
Anyone have an idea about what gains i'd be looking at with those mods.. on american muscle, It's a little over $2000 for it all.
Not to disagree but you cant say a full exhaust system from head to tip doesn't net gains. Headers, xpipe, cai, tune(from the right place), and a cat back system will next about 75hp to the crank in the 5.0. Thats about a 18% gain off of a stock run. Pretty good for naturally asperated parts. Don't think you can do it for 2000 though. Probably closer to 2800 or so the headers depending on brand will be around a 1000. Don't forget unless you have a boom you will be taking that car in to do header work. You have to remove the motor mounts drop the engine a few inches and remove the steering column. its about a 600 hundred dollar job. The rest you can do yourself on jackstands but you will be cursing removing the old pipes.
I'm not calling you out, but where do those numbers come from? I've never heard of documented gains anywhere near that.
Don't take it that way brother. No problem. U can hop on youtube look up 2012 2011 dyno runs and there are cars all over with that exact set up pulling those numbers. It's easy to find because the set up is so common. Not a ton else you can do without forced induction. If a 5.0 gt is running a base line of 365 or so and pulls 410 with that set up add back your 17% loss from the crank to the wheel and there you are.
But as of now, other than the mods I listed, that's about it besides turbo or SC and I wish I could do that, but that'd require forged internals wouldnt it?
