iPhone mount options. - MustangForums.com
Old 03-27-2012, 08:13 PM   #1
Tight Lines
Tight Lines's Avatar
Default iPhone mount options.
I have searched and seen a few mounts but they are not what I was hoping to find. What I was hoping was something that would plug into the 12v hole (not powered just a simple rod with the diameter of the outlet) and an iPhone cradle attached to it. This is the only sore spot I have with my new stang as there is no place to put it, especially if you have two drinks in the cup holder. Anybody see anything like this or similar. May have to make something myself if not.
Anybody try one of these?
http://www.southerncarparts.com/ipho...nt-p-1991.html
Tight Lines is offline   Reply With Quote
Old 03-27-2012, 09:03 PM   #2
alan0614
alan0614's Avatar
I have a similar mount for my GPS from Arkon. I removed the middle part of the unit, so it does not have the hinge part. It sticks directly out of the lighter, works like a champ.
alan0614 is offline   Reply With Quote
Old 03-27-2012, 09:51 PM   #3
Tight Lines
I will check Akron out, thanks.
Old 03-27-2012, 10:08 PM   #4
clowe1965
clowe1965's Avatar
Use a dummy cover/holster and a cutoff 12V plug with superglue. less than 20 dollar solution. Other solution is I can model something on the computer and have a print shop I work with print it out with 3d plastic, but thats going to be 100-200 dollars raw cost (expensive material), I offer my labor free.
clowe1965 is offline   Reply With Quote
Old 03-27-2012, 10:21 PM   #5
Det.FrankBullitt
I had a mount like that. I returned it a day later, it was too unstable.
Det.FrankBullitt is offline   Reply With Quote
Old 03-28-2012, 01:41 AM   #6
pc_647f
www.proclipusa.com. I love mine. Its been very sturdy and they are vehicle specific. Its a two parter, you chose the mount location, then holder. I have an adjustable holder for my evo that accommodates phone cases. Very well made.
Don't mind the mess in the background.
pc_647f is offline   Reply With Quote
Old 03-28-2012, 03:15 AM   #7
outceltj
outceltj's Avatar
http://ecommerce.mossmotors.com/p/mu...system/059-952
I suggest this I have it n my car and it looks like it came from the factory.
outceltj is offline   Reply With Quote
Old 03-28-2012, 08:43 AM   #8
Tight Lines
Thanks for all the feedback. I do kind of like the outceltj posted. I looked up the install and it says you need a trim tool, is that necassary and if so are they available locally?
Old 03-28-2012, 09:50 AM   #9
outceltj
outceltj's Avatar
That same website sells the tool kit for the trim. U can also use a screw driver with a rag so u don't scar the trim. It's easy to do and comes with instructions. It's the cleanest look I found for cell phones
S197 Parts baddog671 Parts For Sale 20 07-26-2016 02:20 PM
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 5 04-04-2016 05:23 PM
iphone/ipod interface to factory hu lincolnshibuya V6 (1994-2004) Mustangs 1 10-06-2015 09:45 AM
Chassis wiggle when off throttle? UrS4 S197 Handling Section 10 10-03-2015 07:23 AM
I should've known better ChampInSD 5.0L GT S550 Tech 13 10-02-2015 05:55 AM
2011, 2012, finding, ford, holder, iphone, iphones, location, mount, mouting, mustang, mustangs, newer, places, s197
