Got an optima red top (pics)
Hey everybody, my battery was toast, and it was time for a new one. I researched a little and decided to give the optima red top a try.
Anyway, just a couple pictures if anybody was curious about fitment.
I had no trouble with install and it fits snug in the box width wise, its a bit shorter length wise though. As you can see the sleave that goes around the battery is a little loose, but its not a big deal. The crankin power on this battery is unbelievable.
I wanted one of those after the battery went dead permanently after winter storage. However when i went to like 5 different auto parts stores they didnt have any and seeing as my stang was undrivable(battery lost its charging capacity) i just went with a diehard. If the battery wasnt in need of immediate attention I probably wouldve ordered one.
Anyway, have you seen UPR's S197 Optima mount?
http://www.uprproducts.com/mustang-b...optima-05.html
Look good man. I'm jealous. When the battery in my '06 died, I was flat broke so I just bought one at autozone. Of course, my racecar which never ever runs has a brand new Optima. I really need to reevaluate my priorities!
Good choice! I am a huge Optima fanboy now. The factory battery is utter ****. By 50k miles, I couldn't listen to the radio for 5 minutes and expect the car to start. The car would sit overnight untouched in a garage and it wouldn't start the next morning. Also my headlights would dim when the bass (on the factory radio) hit.
Put an Optima yellow top in and the power is unbelievable. All problems fixed.. The starter sounds so lively and starts up fast. Optima is the way to go!
I now turn the shaker off before I shut the car off because i heard, if left on, it can still somehow drain the battery even with the car off.
gREAT.
wHATS THE PART OR gROUP # OF THAT THERE RED TOP?
fricken caps lock...
Yellow Tops are not for starting purposes and the life will suffer
from the instantaneous amp draws during starting.
Yellow Tops like to be fully discharged before recharging like trolling motors...
Not for starting vehicles...
