Clutch Engagement Whine
Old 07-07-2012, 07:03 PM
dlazrael
dlazrael's Avatar
Default Clutch Engagement Whine
So, I was running the other day with the radio off (Nothing good on and the ipod died) and I noticed, EVERY time I engage the clutch, to either upshift or downshift, there is a whine that almost sounds like a S/C Whine. (Yes I've checked, no S/C here) Car is bone stuck 08 GT with 36k on it. the whine is most definately from the front end of the transmission (based on where I hear it in the car) and is the same regardless of speed/rpm. Is this normal? or something I should schedule a dealer visit for? I did a forum search and the closest I found was a servo whine thread, but from what is described it doesn't sound like that.
Thanks ahead of time
dlazrael is offline
Old 07-08-2012, 02:20 AM
danzcool
danzcool's Avatar
Synchros.
danzcool is offline
Old 07-08-2012, 02:26 AM
dlazrael
dlazrael's Avatar
OK, so is this a problem covered by warranty? I have the extended plus warranty for a reason Or is it something that is normal? Thanks
dlazrael is offline
Old 07-08-2012, 04:01 AM
Diabolical!
Diabolical!'s Avatar
No it won't be covered by warranty. Synchros are typically going to be considered a wear item and they will blame it on "spirited" driving. Also, extended warranty companies typically try everything possible to avoid covering any damage at all and will try to fight you until you just give up and pay to have it fixed yourself.
Diabolical! is offline
Old 07-08-2012, 11:08 AM
HxCGuitars
HxCGuitars's Avatar
Is it kind of like a whine that quickly decreases in pitch right when you put the clutch in? I've noticed it on mine with the windows up. Can't hear it when the windows are down. The trans also whines a good bit if I slowly accelerate in gear, but nothing I haven't heard in other videos online.
I've come to terms that my transmission is noisy...
HxCGuitars is offline
Old 07-08-2012, 03:56 PM
Calgt08
Calgt08's Avatar
Throw out bearing/slave cyl. They can and will make noise for years.
Calgt08 is offline
Old 07-08-2012, 04:29 PM
dlazrael
dlazrael's Avatar
So further clarification:
There is NO "syncro whine" from standstill/"neutral" when engaging the clutch. The "whine" lasts only for a second or two, and only when shifting about 2500rpm. So I believe you guys are right, its a syncro issue.
Now the question goes, is it anything to worry about? Is the Ford's tranny just noisy? I found a link somewhere that ford DOES cover this with warranty, but is it worth it?
Should I just let it go and see if it gets worse?
Thanks
dlazrael is offline
Old 07-09-2012, 10:12 AM
Simon1
Simon1's Avatar
Mine did for 4 years until it died. There was more of a whine with clutch in than out.
Simon1 is offline
Old 07-09-2012, 10:35 AM
Calgt08
Calgt08's Avatar
They can make noise in or out. Hell I have put in new ones and had them make noise right away.
Calgt08 is offline
Old 01-31-2013, 03:23 AM
dlazrael
dlazrael's Avatar
Question regarding this (old) topic. Do I need an entire slave cylinder or just a new pilot bearing? Also, would it be worth it to have ford fix it (it is under my extended warranty,with a $50 deductable) and then put my own clutch on it this summer when I get FI? Thanks again
dlazrael is offline
Quick Reply: Clutch Engagement Whine
