How long to replace the throw out bearing?
Old 10-09-2012, 09:56 AM
Mike521
Mike521's Avatar
What about a different replacement TOB, like the ford racing one - anyone know if this will last longer? Or am I going to have to look forward to doing this every 80k miles?
Mike521 is offline
Old 10-09-2012, 01:30 PM
Stock Car Mafia
Stock Car Mafia's Avatar
Well I just ordered the Exedy throw out bearing to go along with that clutch. I'll take the advice Diabolical and get it replaced. I've never let a mechanic touch my car over the last year with everything I have done but for this job I am going to bite the bullet and pay someone to do it. I've replaced clutches/TOB on dirt stock cars way too many times on a concrete floor to enjoy this anymore.
Do you have any advice or suggestions with letting someone else do the install? Is there anything I should worn the mechanics about before they tackle the job?
Stock Car Mafia is offline
Old 10-09-2012, 01:40 PM
wayne613
wayne613's Avatar
Originally Posted by Diabolical!
It's such a bear of a job to get the transmissions out of these cars that it doesn't make sense not to change everything while it is out.
There any decent "taco-bill" type walkthru's to changing all this out for our vehicles that you(or anyone else) know of? While everything is fine with mine so far, I'm sure at 78k now it won't be much longer, and I'd like to do it myself.
While the install/removal sections of the workshop manuals will do, they are a bit "dry" to get the feel for all that's necessary for something with this level of PIA behind it.
wayne613 is offline
Old 10-09-2012, 05:26 PM
Diabolical!
Diabolical!'s Avatar
This is a pretty good guide done by forums member "Hammeron". It's not quite taco bill detailed, but taco bill's write ups are so detailed because they're usually pretty small jobs. This is NOT a small job.
http://home.comcast.net/~cookpaging/...ch/clutch.html
If your mechanic has not done a clutch change on a 3V GT before, it would be good to warn him that the transmission will not clear the tunnel without either tilting the motor way back (impossible with some roots/twin screw blowers) or lowering the K-member. He'll appreciate that knowledge when he reaches that point in the job.
Diabolical! is offline
Old 10-11-2012, 10:52 PM
scubastevo87
scubastevo87's Avatar
Not to jack this, but got a question. Is it best to get the flywheel resurfaced or spend the 83 after shipping to get one from newtakeoff? I'm on somewhat of a budget so not sure which would be better and I'll be doing all the work myself.
scubastevo87 is offline
Old 10-11-2012, 11:41 PM
Diabolical!
If it doesn't have any hot spots, resurfacing is fine. If it does, get a new one.
Old 10-14-2012, 09:24 AM
scubastevo87
Thanks for the help!
Old 10-14-2012, 11:36 AM
Diabolical!
Any time.
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
Jskeezy84
09-08-2015 01:40 AM
Urambo Tauro
09-07-2015 12:47 PM
Tyoung68
08-25-2015 04:31 AM
Quick Reply: How long to replace the throw out bearing?
