Rear end noise
Rear end noise
So i have a 2012 GT and had a shop here put in the Eibach Pro spring kit. I love the kit besides the fact overtime i hit a bump i get a noise almost like a rattle out of the back end. Is this normal?
so i did a little closer of a look with a friend sittin on the open trunk. and it seems that the rear axle is surprisingly close to the magnaflow competition catback I have Idk if that is the problem... need to do a little more investigation i suppose.
I finally had enough people to sit on my trunk to re-create the noise. It seems my rear axle vent on top of the axle is hitting my exhaust pipe. Any ideas on a easy fix?
The hangers on the exhaust should give you enough adjustment. Get a large closed ended wrench and slip the hanger through the closed in, you can bend the hangers to make the exhaust work.
Also, since you lowered the car, did you get an adjustable panhard bar? Adjusting the axle would probably move the vent out of the way.
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
