Lca relocation
Lca relocation
Ok I just changed panhard bar upper control arm , had aftermarket lca's now I also installed lca relocation brackets with three holes for mounting points does anyone know which hole to use they are bmr brand bolt in relocation brackets I put the lca in the middle one but not sure if right I'm at stock height, I can't find strait answers during searching, I had serious wheel hop when wet out, TIA
Negatory.
Either have them flat (the length of the control arm parallel to the ground), or a more aggressive setting would be lower at the back side, the relocation bracket end, than the front, chassis end.
Ok must have had a brain fart your right my lca is a little lower on the back what is the results when you say be careful if they are too aggressive
Reason I asked is it bites pretty good now was messing around a lil to test it but I was in second gear taking left hand turn low speed, hit gas a lil mid turn and I did get a lil fish tail I didn't expect was wondering if it was something on the road, or the changes I made yesterday that I wrote in first post, it was dry and nice out, but wasn't sure if I hit oil or like I said my changes in rear
