Shifter Install help/question
Old 11-27-2012, 09:42 PM
julezzTx
julezzTx's Avatar
Default Shifter Install help/question
Just wonderin if the shifter install is as simple and straight forward as explaind in the instuction and vids. Ither the hurst or the MGW. Cant find a shop that will do it so Im thinking about planing to do it myself and was wanting to get feed back from people that have done it themselves
julezzTx is offline
Old 11-27-2012, 11:51 PM
Diabolical!
Diabolical!'s Avatar
Piece of cake. Easiest method is to remove the driveshaft first, but you don't have to if you don't mind installing a couple of bolts by feel.
Diabolical! is offline
Old 11-27-2012, 11:58 PM
aquajr
aquajr's Avatar
A buddy and I installed one in my car in a couple hours. We were scratching out heads for a bit while removing the center console. It just took a lot more muscle than I though but nothing was damaged.
Like Diabolical said if you don't remove the driveshaft you'll need to do some wrenching by feel. There was one bolt that was really hard to get aligned and threaded right.
aquajr is offline
Old 11-28-2012, 12:51 AM
HxCGuitars
HxCGuitars's Avatar
I pretty much followed the MGW videos, ran into nothing unexpected. Very, very easy.
HxCGuitars is offline
Old 11-28-2012, 08:24 PM
Goldenpony
Goldenpony's Avatar
Do yourself a BIG favor and go with the MGW.
Goldenpony is offline
Old 11-29-2012, 10:01 AM
AMWill
Former Sponsor
AMWill's Avatar
OP,
Whether you decide to go with an MGW, Barton, or Hurst shifter, I would definitely save yourself some money and do the installation at home! Check out our Barton shifter install video when you get a chance. It's a step by step video that shows you exactly how to install their shifter (which would work for MGW or Hurst as well), so you know what you're in for. I think you'll find that the installation is fairly simple, plus it's always cool when you've personally installed aftermarket parts on your Mustang!
Hope this helps you out, at least with the install video!
Shane
AMWill is offline
Old 11-29-2012, 12:59 PM
julezzTx
julezzTx's Avatar
Originally Posted by AMShaneLesky
OP,
Shane
Thanks for the link Shane it really does seem farliy simple I will up date once instaled again thanks to every1 for all the help
julezzTx is offline
Old 11-29-2012, 01:40 PM
acascianelli
acascianelli's Avatar
I installed my Hurst in my driveway with a set of ramps. The hardest part is getting the shifter arm through the hole from the top but it is possible, you just have to find the right angle. You shouldn't have to remove the center console or drive shaft.
acascianelli is offline
Old 11-29-2012, 02:46 PM
Goldenpony
Goldenpony's Avatar
It's a fairly easy, straight forward install. I installed my MGW on a lift. I would imagine it's a LOT easier than doing it on jack stands. Just watch the videos several times . Take it slow and follow the instructions. When they tell you to tighten something with a torque wrench, DO IT!.
Old 11-29-2012, 04:31 PM
Shelty
Shelty's Avatar
it took me an hour tops to get my hurst shifter into the car. including jacking up the car and everything
you dont need to remove the console on the 05-09 models, tho I do recommend that you put some painters tape around the shift hole, so you dont scratch the plastic
Shelty is offline
Quick Reply: Shifter Install help/question
