Just got a used strut tower brace for my 05 GT
Old 01-12-2013, 02:34 PM
rfomlover
rfomlover's Avatar
Default Just got a used strut tower brace for my 05 GT
I just got a used strut tower brace for my 05 GT but I just realized that it is for a V6. Will this strut tower brace work on my GT? I test fit it over the studs and everything lines up right but just want to make sure it won't hurt the car.
rfomlover is offline
Old 01-12-2013, 03:08 PM
go-part
Former Sponsor
go-part's Avatar
It may not hurt the car, but it wont provide the same effect.. I dont know if it will be as rigid as the v8 version..
go-part is offline
Old 01-12-2013, 03:14 PM
mapitts
mapitts's Avatar
You can check and see who made it and who it was sold by. See if the part numbers are the same. $20 says it will work.
mapitts is offline
Old 01-12-2013, 03:26 PM
duckbubbles
duckbubbles's Avatar
You'd have to install it to check for hood and engine clearance, but if it's clear, run it!
Frank
duckbubbles is offline
Old 01-12-2013, 04:33 PM
rfomlover
rfomlover's Avatar
It's steeda and the bag says V6.
Old 01-12-2013, 04:34 PM
SD 197
SD 197's Avatar
I believe the V6 strut bars are higher than the V8, see how it clears your hood.
I think the 4 strut bolts are set at 27 ft-lbs when you tighten them up.
SD 197 is offline
Old 01-12-2013, 05:47 PM
Moderator
JimC's Avatar
The V6 strut bar sits higher to clear the higher intake manifold on the 4.0 so the center of the brace is higher. Other than that there really is no difference. You will just have a little more clearance than the V8 specific bar would have between the brace and your intake manifold; probably not something that anyone would even notice. But fitting under the hood will not be an issue since the V6 and V8 both have the same hood and the same strut towers up front.
JimC is offline
Old 01-12-2013, 06:56 PM
rfomlover
rfomlover's Avatar
Ok so it won't bend the strut towers or anything under hard handling?
Old 01-12-2013, 07:59 PM
05screaminyellow
05screaminyellow's Avatar
i dont think you should take a chance with it.... box it up and ship it to me
lol it will work fine in your car
05screaminyellow is offline
Old 01-12-2013, 08:20 PM
mapitts
mapitts's Avatar
Same basic body style for both. Weather it is a V6 or a V8. Hood design & strut tower heights are all the same. You are good to go. 05screaminyellow, that is a nice color.
mapitts is offline
Quick Reply: Just got a used strut tower brace for my 05 GT
