should i go 4.6 or 5.0
Old 05-18-2013, 12:08 AM
sl1mm80
sl1mm80's Avatar
Default should i go 4.6 or 5.0
Hey guys and girls, I'm new to the site(no need for welcomes thank you tho) and I am looking to buy a 05 or newer mustang. I have plans to supercharge and swap cams on the motor and hit a minimum of 500hp, I also plan to do the work my self. I really like the 05-09 body and i know there is more chargers available for the 4.6, but really like the thought of saying it has a 5.0!!! so '12-13 so I guess I'm asking which is easier to work on which parts are cheaper and which would be all around better for my needs
P.S. sorry if i start a war between 4.6 guys and 5.0 guys!
sl1mm80 is offline
Old 05-18-2013, 01:12 AM
Ricardo
Ricardo's Avatar
Well, I went to a local dyno day. My 07 GT put down 275hp at the wheels 91 tune/JLT intake/Bassani axle backs/4.10 gears. A 5.0 with ONLY tune/intake/GT500 axle backs put down 423hp to the wheels. That says everything about the vast difference between what these engines put out.
The coyote isn't just hype. As a 4.6 owner I say get a 5.0.
4.6 parts are cheaper but a full bolt-on 5.0 matches a 07-09 GT500 on the street.
edit: I'm trading up for a '13 as soon as the '15s come out.
Ricardo is offline
Old 05-18-2013, 01:53 AM
E_cox310
E_cox310's Avatar
I prefer the body style of 4.6 as well, but you'd be a fool to get a 4.6 if you can afford a 5.0 at the moment. The 5.0 engine is far more superior. This shouldn't even be a question
E_cox310 is offline
Old 05-18-2013, 09:34 AM
MustangInTexas
MustangInTexas's Avatar
I'd say the 5.0 is a much better engine as well. But, just sos ya knows, the 5.0 came out in 2011. That gives you one more year to look at for the 5.0.
MustangInTexas is offline
Old 05-18-2013, 12:08 PM
aaaa1236
aaaa1236's Avatar
Not even close
The 5.0 can hit your 500 mark N/A
The 4.6 will need f/i of some sort
aaaa1236 is offline
Old 05-18-2013, 12:47 PM
danzcool
danzcool's Avatar
If 500 is your ultimate target and you plan to supercharge, the either will work fine. The aftermarket parts should be cheaper for the 4.6 but they are no longer casting the 4.6 blocks, so if eventually you want to go forged, you can easily get a brand new 5.0 block but the 4.6 will likely be a refurbished block.
All that said, I know when it comes to BIG power there is a weakness in the 5.0 design currently that hopefully will get worked out (the sportsman block is an attempt to resolve that weakness).
But at under 600 on the 5.0 you would be nowhere near the level to cause any issues with the current design.
danzcool is offline
Old 05-19-2013, 07:20 PM
SpartaPerformance
SpartaPerformance's Avatar
It;s all up to your budget. 500HP can be easily achieved with a 4.6L reliably. An FRPP, Roush, or Edelbrock blower can be installed and you're done no need for cams etc...
SpartaPerformance is offline
Old 05-19-2013, 07:42 PM
Nuke
Nuke's Avatar
I'd be a little concerned with a 4.6 running much over 450 RWHP unless you forge. I'd definitely go with the 5.0 if it's power you're after. With the 4.6, you'll need a good bit of suspension work to go with that SC. With the 5.0, not as much.
Nuke is offline
Old 05-19-2013, 08:28 PM
mustangspotential
mustangspotential's Avatar
I like the 4.6 and the 05-09 body style as it's what I own, but there's no doubting that I long for a 5.0 and the new body style. If money isn't an issue, obviously the five-ohhhhhh.
mustangspotential is offline
Old 05-20-2013, 01:22 PM
Rockriders30
Rockriders30's Avatar
Definitely get a 5.0
Rockriders30 is offline
Quick Reply: should i go 4.6 or 5.0
