Squeaking brakes (TSB)
Old 10-05-2005, 05:31 PM
mustang mac
mustang mac's Avatar
Default Squeaking brakes (TSB)
Hey all
Somewhere around 14,000 miles my GT 05 started a squeaking noise (not metal on metal) when I applied my brakes with medium pressure. After trying several home solutions I finally had enough and took it to my Ford dealer last weekend. The shop foreman said it might be faulty rotors and had the mechanic change the rotors. The test drive after the rotor replacement caused the squeaking noise with and with out braking so back on the rack it went.
They then found a TSB on changing to brake pads to a different type and shape. Well that fixed it. No more squeaking brake problem.
mustang mac is offline
Old 10-05-2005, 05:37 PM
Professor Wizard
MF Moderator
Professor Wizard's Avatar
Default RE: Squeaking brakes (TSB)
Cool.. so you got a brand new set of rotors out of the deal!
Professor Wizard is offline
Old 11-03-2005, 01:10 PM
Dilligaf
Dilligaf's Avatar
Do you have the TSB number on the squeaking brakes? My 2005 V6 squeaks soooo bad I can't drive with the windows down. It is embarassing rolling up to a stop light with the loud exhaust and even louder brake squeal.
Thanks!
Scott
Dilligaf is offline
Old 11-03-2005, 03:14 PM
Stone
Stone's Avatar
Same deal here 12,000 and started to hear same squeek soft breaking only for now.
If you can find the TSB # please post it.
Thanks
Stone is offline
Old 11-03-2005, 04:36 PM
torch red
torch red's Avatar
aaaahhhh tsb? shaazaam!
torch red is offline
Old 11-03-2005, 07:12 PM
DAVE05GT
DAVE05GT's Avatar
Mine is at the dealer right now for the same problem and few other minor things. I couldn't find the tsb either but hopefully they will find it and fix it. If they do I'll post the #.
DAVE05GT is offline
Old 11-03-2005, 08:18 PM
Stone
Stone's Avatar
I had to goto dealer to get my car so i asked about this and i got a copy.
TSB
05-18-10 BRAKE NOISE-VEHICLES BUILT BEFORE 3/8/2005
FORD 2005 Mustang
ISSUE:
Some 2005 Mustang vcehicles build before 3/8/2005 may exhibit occasional brake noise during light to moderate
decelerations from speeds below 40 MPH (64 Km/h), often described as a high-pitched squeal or screech.
ACTION:
Install revised rear brake linings following procedures in workshop Manual Section 206-04. Do not replace or turn
rotors, and do not service the front brakes for this condition.
PART # PART NAME
5R3Z-2200-B Disc Brake Lining
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATOION DESCRIPTION TIME
051810A 2005 Mustang - install Revised Rear Disc Breake Linings
(Do Not Use With 2001BBB,2001B1BB) .6 hours
DEALER CODING
BASIC PART NO. CONDITION CODE
2200 42
Stone is offline
Old 11-04-2005, 04:47 PM
Getaway
Getaway's Avatar
My build date is after the date in the tsb, and I'm getting the brake squeel....got roughly 13,000 miles. I thought it was just the rotors since they tend to rust over pretty badly quite often...thanks for the tsb info!
Getaway is offline
Old 11-05-2005, 06:13 AM
DAVE05GT
DAVE05GT's Avatar
Dealer ordered the new brake pads and should be here next week. FYI, they're also fixing the drivers side door handle and the leaky master cylender cap.
DAVE05GT is offline
Old 11-05-2005, 07:14 PM
toolttime
toolttime's Avatar
Speaking to you as a licensed mechanic. It happens on my 05 roush also.The squeal you hear from your brakes is not caused by the rotor but from the back metal side of the brake pads against the caliper piston and cailper mount area where the back metal side of pad touches the caliper. This area usaullly developes rust. When you buy new pads there is usually a stick on paper to stick to back metal side of pad. this is to stop squeaks. There is also a squeal stooper which is applied to back side of pads and it makes like a rubber pad. A quick fix to the squeal is to use WD40 and give the back side of pads only "not" the the between pad and rotor but on the backside where the metal back side of pad meets the caliper. It don't take much just alittle squirt and it is fixed as easy as that. Most wheel you don't even have to take off to do this.
[IMG][/IMG]
toolttime is offline
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Squeaking brakes (TSB)
