WTF are these things and where do I get a pair?
Old 12-30-2013, 01:25 AM
ErnestBlair
ErnestBlair's Avatar
over painting with enamel before the installation is a good suggestion and by the way, it is going to lessen the concerns of the cleanliness of your wheels and you will not be restricted by any weather road conditions
Tevida Side Effects
ErnestBlair is offline
Old 12-30-2013, 10:32 AM
sbradle4
sbradle4's Avatar
Honestly, you could probably take some steel wool to that to see if that is just surface oxidation. If it is, take the braces off, and put a few coats of rustoleum on it, and bolt it back up. Unless it is rusted holes through the brace or it has rusted enough to change shape, you are probably fine.
sbradle4 is offline
Old 12-30-2013, 12:31 PM
Goldenpony
Goldenpony's Avatar
^That's what I had hoped for, but after a second look, they both need to be replaced.^
Goldenpony is offline
Old 12-30-2013, 02:49 PM
Goldenpony
Goldenpony's Avatar
This HAS to be wrong. I just stopped in my local Ford dealer. The parts guy said this brace is priced at over $500 each. Doing some more investigating.
Old 12-30-2013, 04:05 PM
Goldenpony
Goldenpony's Avatar
Default Parts sticker shock!
After checking into it, evidently, these parts do run about $500 each. This is insane. They're just a piece of square steel tubing with a bend in one end and a couple of bolt holes in each end. I've even called some salvage yards but so far, no joy.
Anybody else run into this problem? I have attached a pic from the Ford parts manual. It is part 102B54. Look like a $500 part to you?
Attached Thumbnails WTF are these things and where do I get a pair?-scan0014.jpg
Old 12-30-2013, 06:24 PM
sbradle4
sbradle4's Avatar
This is white lake ford (formerly Tousley). They usually have great deals on their OEM parts by comparison.
https://parts.autonationfordwhitebea...upport%20brace
sbradle4 is offline
Old 12-30-2013, 06:40 PM
pascal
S197 Section Modder-ator
pascal's Avatar
Have a custom shop fabricate some for you, shop around.
I guarantee you that it'll be cheaper than $500 a piece.
They're not complicated parts (square tubes basically) and they don't have to look exactly the same, they're basically straight.
Hell, a 1/4" flat piece of steel by 1.5" wide cut to length would do the trick I say.
File down the sharp edge for looks and voila.
pascal is offline
Old 12-30-2013, 07:12 PM
Goldenpony
Goldenpony's Avatar
This is a little better, $734 for the pair plus whatever shipping. Still Hiway robbery. I will keep it in mind though.
Old 12-31-2013, 07:29 AM
S197GT07
S197GT07's Avatar
You could just get a pair of SFC from BMR for a fraction of the cost, since they replace the vert bars anyway.
My .02
S197GT07 is offline
Old 12-31-2013, 03:07 PM
Goldenpony
Goldenpony's Avatar
Default Braces
I think I have come up with a good plan "B". BMR sub frame connectors. $260 and should be much better. Need to be welded in.
Quick Reply: WTF are these things and where do I get a pair?
