Misfire problems
Since you have Detroit cams, I'd pull the cover and inspect the cam and rockers. You have have scoring on the cam and/or a broken rocker. Or, your tensioner could have failed and not be keeping enough tension, or your chain jumped.
Since you've ensured it is not a plug or cop issue, and since the cams were replaced, the logical choice would be a mechanical issue there, assuming the alternator is producing 14 volts and you have adequate oil pressure.
Omgitsa88Stang
10-05-2015 07:33 AM
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
