caliper cover help
Old 01-13-2014, 10:21 PM
blkgt08
blkgt08's Avatar
Default caliper cover help
I bought mpg caliper covers and am having alot of fitment issues on the rears. The clips that hold the cover onto the caliper are grinding on the topside of the rotor and making a very loud squeal. Iv tried to bend the clips etc and its still in contact with the rotor. I have stock bullet 18's and drilled slotted rotors. Does anyone know how to fix the clearance issue or somehow install the covers without the clips? Iv ran out of ideas and would really appreciate any help
blkgt08 is offline
Old 01-13-2014, 10:47 PM
dkpGTCS
dkpGTCS's Avatar
I don't know if I can help but I just installed mine this past weekend and had the same issues. I ended up redoing the rears last night. I was able to readjust them to a point where a piece of paper would slip through. Then I had to hold them in place while tightening them down. Didn't eliminate the noise but got rid of most of it. (The first attempt was so loud it was embaressing.)
I ordered new drilled/slotted rotors from AM yesterday so I figure will take them off next weekend anyway...
I will say that it is an extremely tight fit - and from I found many people have the same problem. Some said that sanding the clip down helped. Some others said they trimmed the clip down - not sure I would try that as it seems it would come off easier. If I have any issues next weekend with the rotor replacement I am going to try the sanding route.
dkpGTCS is offline
Old 01-13-2014, 11:01 PM
blkgt08
blkgt08's Avatar
Im gonna try and sand them down as well. Someone I know notched their clips but they drive an Acura. All I know is its a pain in the *** and the noise is definitely embarrassing
blkgt08 is offline
Old 01-13-2014, 11:31 PM
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
Have you tried calling them and see what they suggest?
MELLOWYELLOW06 is offline
Old 01-14-2014, 02:27 AM
blkgt08
blkgt08's Avatar
I was planning on calling the manufacturer tomorrow
blkgt08 is offline
Old 01-14-2014, 08:20 PM
blkgt08
blkgt08's Avatar
The manufacturer told me to raise my caliper...loosen the bolts and put two flat head screwdrivers beneath the caliper to raise it a bit and tighten the bolts back up. Is this actually possible or just a dumb idea?
blkgt08 is offline
Old 01-14-2014, 08:27 PM
xx10Gt
xx10Gt's Avatar
i dont see how thats possible... the bracket is held on by 2 bolts as well as the caliper. Its in a fixed position.. unless im not fully understanding what they mean.
xx10Gt is offline
Old 01-14-2014, 08:44 PM
blkgt08
blkgt08's Avatar
Exactly. I do my own brakes and do not at all see how that will fix the clearance issue. These covers are becoming a headache
blkgt08 is offline
Old 01-14-2014, 08:49 PM
xx10Gt
xx10Gt's Avatar
i had the same problem with the mgp covers on my old '10 gt. eventually i bent the clips to get them to work and they were fine ever since. sucks when you cant get something to work right.
xx10Gt is offline
Old 01-14-2014, 10:19 PM
Cruzinaround
Cruzinaround's Avatar
That's a dumb suggestion on their part. If you can do this it would pull some of the pad over the edge of the rotor. The pads could wear abnormally.
Long way to go for a caliper cover.
Cruzinaround is offline
Quick Reply: caliper cover help
