Clunky Spider Gears on a 2005 GT 5 Speed
I have an 05 Mustang GT 5 Speed. I bought it with 49,000 miles on it, and I have since put about 4,000 miles on it. I am getting a pretty bad clunk in the rear end.
It appears to be coming from the spider gears. I hear the clunk when I get off the clutch during a shift and sometimes when i get on the clutch. It is at it worst when I shift in the middle of a turn. I took the back cover off and you can see the slop in the spider gears when you try to move the pinion with the e-brake set. I checked the back lash and it is within spec. There isn't any slop in the stock 2 piece drive shaft. Here is a video of the noise.
http://www.youtube.com/watch?v=MD2Sv...ature=youtu.be
Anybody else had this problem? I was thinking of replacing the spider gears and cross pin, but American Muscle sells the whole Traction-Lok unit for $230. Any thoughts or ideas?
After I had the back cover off, I replaced the fluid with 2.2 quarts, which is what the owners manual said. It wasn't running out of the fill hole. You think adding more fluid might quiet it up a bit?
Ive read that 9 times out of 10 its the stock drive shaft clunking, but in this case its not.
More is better than less in this situation.
Any excess lube will exit the vent tube over time.
musnicki
09-23-2015 07:11 AM
