rear end 3.73...4.10
Old 03-20-2014, 11:16 AM
  #31
drewsky
drewsky's Avatar
A 3:55 to 3:73 is immediately going to make you wish you had more. You won't even feel the difference really. I debated between the 4:10-3:73 for months. You won't get much worst gas mileage, about 1mpg less overall.. It's soooo worth it for what it does to the car. You said yourself everyone says go ahead with the 4:10's and I'm adding to the list! DO IT you will have no regrets!
drewsky is offline
Old 03-20-2014, 05:54 PM
  #32
retfr8flyr
retfr8flyr's Avatar
Originally Posted by J7erry
I have a 2013 auto with 2.73 right now and I'm thinking about going to 3.73. Will this make a difference out of the hole? I only have the CAI right now but am planning on getting a Obama tune soon. Just wondering if it's worth the expense.
With the 6R80 automatic, if you want the best 1/4 mile times then install either 3.15 or 3.31 gears. Anything more is just a waste of time due to the gearing in the 6R, hell it's got a 4.17 first gear. Go with 3.15's if you're basically stock and 3.31's if you have a few bolt on's and a CAI. This will have you going through the traps at the top of 3rd gear. You don't want to be shifting into 4th gear, not only does it cost you ET but 4th is a weaker gear with less clutch packs then 1-3rd gears.
Also get your tune from Mike Rousch at Mid Atlantic Performance 1-804-332-6685 - Email: Mike@MidAtlanticPerformance.net. Mike has really figured out the new 6R and 5.0 combination in the new Mustangs. His personal, naturally aspirated, 5.0 has been 11.16@123 with a 3.15 gear and 275/50/15 drag radials.
retfr8flyr is offline
mtgldr
02-03-2024 09:00 PM
zsmart
Convertible Tech
02-29-2016 08:33 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
fastbackford351
09-12-2015 09:42 AM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: rear end 3.73...4.10
