Spark Plug change advice
Old 02-16-2014, 12:50 PM
Mustang7599
Mustang7599's Avatar
Update: Lisle tool worked great! Although the pusher did break the metal loop at the tip of the plug even though it wasn't supposed to be able to.
I considered warming the car, but it is in tucked in for the winter and didn't want to have to get it "un-tucked".
I got some clear plastic tubing and used the shop-vac to suck out the cylinders. Then pulled the fuel pump relay and turned the car over to get anything else out. Haven't put in the plugs yet, but that should be uneventful! Thanks for the help guys!
Mustang7599 is offline
Old 02-16-2014, 06:06 PM
Goldenpony
Goldenpony's Avatar
No harm, no foul..
Good job.
What kind of plugs are you going back with?
Goldenpony is offline
Old 02-25-2014, 09:02 PM
pinche_maniaco
pinche_maniaco's Avatar
now quick question are those plugs pre gapped or do i need to do so and if i do need to how the heck do i ???
pinche_maniaco is offline
Old 02-26-2014, 09:04 PM
bryan67
bryan67's Avatar
if you can do it after the engine is warm. It is the safest way IMO. let the car run 5-10 mins the go ahead and swap out your plugs. crack them lose use a little penetrant or even a few drops of thin all purpose oil works great. I use the lite oil on a warm engine and have never snapped a plug or torn out the threads. On a newer engine.
bryan67 is offline
Old 02-27-2014, 02:41 AM
DCzapla
DCzapla's Avatar
If i use new ford motorcraft plugs has the design of the plug changed so this isnt a problem?
DCzapla is offline
Old 02-27-2014, 08:05 PM
Mustang7599
I used Autolite...which I understand are the same as Motorcraft. I believe all plugs (that I know of) for our cars are pre-gaped.
Old 02-27-2014, 10:04 PM
Goldenpony
Goldenpony's Avatar
It's still a 2 piece plug. Why in hell hasn't that changed?
JonnyBlazeGT
11-03-2015 01:10 AM
movielover40
08-27-2015 10:13 PM
1st 4 eyed fox
08-24-2015 06:56 PM
overnight89
08-22-2015 09:02 PM
Quick Reply: Spark Plug change advice
