Can't seem to lower gas tank for UCL bracket install
I have dropped the fuel tank straps, and it won't budge an inch.. it's still solidly in place?? What am I missing? Instructions don't mention anything else to get tank to drop down... help?
Thanks, but all it seems to show is that by droping the straps the tank should lower a bit anyway.. just need like an inch or so to get that ucl bracket out, but it's like the tank is still bolted on.. I can hang on it and it doesn't move 1mm!!! At this point I think I'll just use the stock UCL bracket. I think my problem was the stock ucl's rubber bushing, and the factory mount should be fine.
I think some of the tanks get the coating stuck to the top of the sheet metal. I dropped mine many years ago but I also had some trouble getting it down after the straps were removed. How much gas is still in the tank, I hope it's almost empty? When you do get it to release be careful, as it will drop fast.
Well.. as luck would have it, I shipped the ucl bracked back, then that evening as I was trying to get the bolt attaching the stock ucl to the stock bracket out.. the %$#^% gas tank came loose and dropped down! guess it just needed a little persuasion to work loose. Now I need to ask UMI to ship the link back (once it gets to them) *sigh*
