2006 Strut Replacement
I will be installing Koni Yellows soon on my 2006 GT. The car has 60K on the clock. Are there any parts I should think about replacing while I have the struts out? I am using the newer style lower fine thread bolts. Any wear parts that are worth replacing on the tops?
I currently do not have any noise or popping.
Yep. Since you're in there replace the strut mounts. Helps the ride.
http://www.americanmuscle.com/frpp-g...ount-0512.html
