Should I buy this supercharged 2005?
Old 05-04-2014, 04:40 PM
  #21
moosestang
moosestang's Avatar
Originally Posted by wcgman
So you run a higher risk with a SC'd car than you do with NA...big deal. If it's done right and the car was treated well then there's a higher risk for sure but it's somewhat marginal. It's pretty hypocritical of us to get on here and start telling this new guy "I wouldn't do it because..." then turn around and in other threads start saying "totally boost that, you'll never regret it!". It's not like any of us built these superchargers by hand and signed off on them personally. Best case, 95% took it to a mechanic who followed instructions from the vendor, then 5-6000 later we're done and happy, then 4% braved following instructions and over a weekend with a friend or 2 installed it, then 1% actually put forged components in and installed the SC. We all know most of the mistakes that have been made have been either poor maintenance, bad install, or abuse. Very few have probably had mechanical failures because going over 400hp at the crank. Face it, you very likely didnt build nor install your supercharger, so why do you write off every other guy's car who did as being inadequate because they put it on autotrader or CL? My rule of thumb would be get the kbb on the car, add maybe 4-5k depending on the mods, then lowball the heck out of the seller hoping they cave, but be ready to pay that amount because that's fair.
My advice to buy a stock car and install your own supercharge, which i did do myself, is simply because of price. The car in question is overpriced, because they want to get all the money out of it for the mods. If he's financing this, then fat chance any bank will give that much on a lone for an 05. If he's paying cash anyway, then just buy a new supercharger, instead of paying new supercharger price for someones used one.
moosestang is offline
Old 05-04-2014, 08:05 PM
  #22
outceltj
outceltj's Avatar
Originally Posted by quinnbristow
Hmm... Now I'm thinking about forking out some extra cash and buying a newer 5.0..
I'm really looking for acceleration, how would you guys say they compare?
It seems that all the Mustangs that i've seen are built to the blowing point with no forged internals, so lets use that as a benchmark.
Blowing point 4.6 vs stock 5.0.
Opinions?
Not a good comparison two different platforms. It comes down to financing for you and what you can afford. If you are taking out a loan for even 60 months I say no but its your money.
outceltj is offline
Old 05-04-2014, 08:09 PM
  #23
outceltj
outceltj's Avatar
I agree with your statement but I think most will agree the car is too much. As im sure you do. Would Id be afraid to buy a supercharged car. Might be hesitant just b/c of not knowing who tuned or what said tuners reputation is.
outceltj is offline
Old 05-07-2014, 01:04 AM
  #24
quinnbristow
quinnbristow's Avatar
Here is the newest one that I like.
http://westslope.craigslist.org/cto/4457401777.html
I think it's too much, and I it doesn't have much description. However, does it sound like a good car?
quinnbristow is offline
Old 05-07-2014, 09:07 AM
  #25
outceltj
outceltj's Avatar
Too expensive and he claims 500hp at 6 psi. Highly unlikely 450 tops.
outceltj is offline
Old 05-07-2014, 11:43 AM
  #26
Quake Guy
Quake Guy's Avatar
yep, I have 366hp to the wheels at 7psi and LT headers. Its an automatic so assume 17% losses and its 440hp at the crank. Dyno is conservative and tuner is one of the best for Fords in Phoenix metro.
My car has a ton more mods than that and 16k less miles, however has had the misfortunate of being in a wreck due to a hit an run drunk.
Which brings me to this, don't want to be the spoilsport here, but here has been my experiences with a modded car.
When it comes to insurance, good luck getting money out of your mods. Perhaps you can do a stated value at some places, but I am sure they will charge you plenty for it. Otherwise with Geico, if I declared my mods and paid extra, I was told covering the mods would be taken into consideration when determining whether to repair or total. However, if they total the car, they will not pay for the mods.
Also, my supercharger was installed by a prior owner by Sanderson Ford. They are supposedly a FRPP certified dealer and the best dealer in town when it comes to performance installations. Prior owner also taken the car to a performance shop for additional mods. Once I got it, the car was throwing expensive serpentine belts left and right. I was measuring miles per belt. I took it to a local shop that had some experience in performance stuff, but that wasn't their primary focus. Belt broke again and they replaced it again. After all that, the tensioner arm finally broke killing the belt again.
By then I took it to the new tuner guy I found. After something so outlandish as reading the whipple instructions, we discovered that the S/C was never properly installed with the right tensioner arm modifications nor with the later mods had the correct size idler arm pulleys been installed.
My moral of the story, finding people who know what the hell they are doing is a lot harder than it seems. Especially nowadays. So if you are not turning your own wrenches, there is something to be said about a stock car. And it sounds like you are off the beaten path. This was my experience in metro Phoenix, if you are in the sticks, good luck.
Quake Guy is offline
Old 05-07-2014, 01:14 PM
  #27
Derf00
Gentleman's Relish
Derf00's Avatar
Yep and yep.
60 months on used car is too long. Even new is pushing it. For used 36 months max. New I generally stick to 48.
Derf00 is offline
Old 05-07-2014, 09:17 PM
  #28
outceltj
outceltj's Avatar
I also asked that guy about his car on craigslist. I asked for a Dyno file and this is what he sent me
I also have a main overdrive pulley if you want it. With both of them on it blew the motor(cracked the pistons the weakness in this engine) the supercharger was originally on.
outceltj is offline
Old 05-07-2014, 10:17 PM
  #29
Rudolph Hucker
Rudolph Hucker's Avatar
Originally Posted by Derf00
Yep and yep.
loaning money for ANY used car is madness imho.
loaning for 36 months on a new car would be my limit if i ever borrowed for a car.
i have never loaned money for a car though..
Rudolph Hucker is offline
Old 05-07-2014, 10:39 PM
  #30
quinnbristow
I wish I could afford a car like this in cash, but I'm only 19. Haha.
If this car is making 400< HP, that comforts me a little. I don't want anything pushing too hard.
I don't know if you are speaking ironically about the dyno files, or if a link/picture failed to post.
Out of curiosity, how much does it generally cost to upgrade the rotating assembly to be reliable with the added power of a SC?
Quick Reply: Should I buy this supercharged 2005?
