Window and stereo problems
Hello
Got a problem with my 2005GT.
Windows won´t go upp and the stereo will only start when I pull the front windows button half way down.
When I lock the car the front windows wont go up, so there´s a gap..
I´m thinking of fuse problems but none of the fusese are broken.
Sorry for my spelling
Hailing from Sweden
/Dave
Hailing from Sweden
/Dave
Sounds like you need to recalibrate the windows, doors closed, I like to turn everything off, radio, heat, and car not running, to key to on position but don't start, open window all the way and hold button for an extra 2-3 seconds after it reaches full open, then roll up window and hold for 2-3 seconds after window fully closes, should take care of it. If not there is some other reset I can't think of right now, but someone else will probably post it.
Looked in to the reset part but dosent work.
So I checked the 5amp fuse #6
replaced it nad when i have the key in the fuse doesen´t blow. but when I start the car, ut blows in i sec.
Checked the relay and it works just fine.
Maybe a ground problem,have to check the wiring from the door.
zanemoseley
09-06-2015 12:58 PM
